Unread 01-04-2012, 01:34 PM   #1
HomeDepotAssociate
HomeDepotAssociate's Avatar
Building up thinset on a wall?
Short question. Building up thinset on a wall to aleviate slight bumps in wall. Can it be done safely, and how much can you build up the tinset?
Kontorsion
(Chate')
HomeDepotAssociate is offline   Reply With Quote
Unread 01-04-2012, 01:35 PM   #2
Yes it can be done. 1/4" is the maximum.
Unread 01-04-2012, 03:31 PM   #3
Bumps or Dips ?
Unread 01-05-2012, 12:32 PM   #4
HomeDepotAssociate
1/4 maximum, thankyou. I said 1/4 or 3/8ths, but wasnt confident. I believe it was bumps too. Sorry for the late resposne, sometimes i post questions and then get carried away at work and forget to check back
Kontorsion
(Chate')
Unread 01-05-2012, 12:55 PM   #5
Bumps will be tough, since you have to fill the entire wall to the same level. It may be easier to re-work the drywall to remove those.
Unread 01-05-2012, 06:33 PM   #6
Lazarus
Lazarus's Avatar
Yeah, bumps need to be ground down. Valleys are a bit easier. On a job today where the wall had a valley of about 1/4 inch. Mixed up some Laticrete 317 and floated it....put a fan on it and re-did it later. I didn't "fix" it, but I helped it. Screeds and wall mud are the best choice....but this was what I had to work with, but you can't do more than 1/4" at a time.....
Laz...
building a knee wall for alcove tub nyartist Tile Forum/Advice Board 3 08-16-2008 10:55 PM
SHower Building 101??? what wall material apalma002 Tile Forum/Advice Board 4 03-08-2008 05:41 PM
Building up low spots with thinset? whk Tile Forum/Advice Board 5 10-10-2007 05:16 PM
building a glass block wall in my shower Boy Scout Tile Forum/Advice Board 5 09-08-2007 07:22 AM
building out wall to be even with tile medik13 Tile Forum/Advice Board 5 01-28-2006 08:47 PM
