Unread 05-30-2011, 07:58 AM   #1
lnb001
warm tiles thermostat malfunction
Hi all,
I have finally finished my bathroom remod and have been enjoying my heated marble floors for a couple months now. While away this weekend my wife said there was a power outage for about an hour. After her shower she said she noticed the floors were ice cold. When I got home the programmable thermostat had no display but the GFI indicator light was on. I tried hitting test and reset several times, switching the mode from off to manual to auto to no avail. I tried flipping the breaker on and off but that didn't do anything either. Is this thing fried?
Lucas
Lucas
lnb001 is offline   Reply With Quote
Unread 05-30-2011, 09:43 AM   #2
Muddman
Muddman's Avatar
Sounds like you just need a new controller, I wouldn't panic that the floor system is shot, yet.
Gregg
www.muddmandesign.com
Muddman is offline   Reply With Quote
Unread 05-30-2011, 11:51 AM   #3
dhagin
I'd check the t-stat installation/trouble-shooting instructions. I'd also call the t-stat manufacturers tech support and tell them your issues. They are best to direct you about their product.
Might need a new t-stat, but it might just be something simple as well.
dana
Unread 05-30-2011, 05:37 PM   #4
tileguynky
I had a similar problem with the t-stat in my daughter's bathroom. Seems that when the GFCi popped, it shorted out the t-stat. I was shipped a new one and received it with in a few days.
Unread 05-31-2011, 07:10 AM   #5
lnb001
Contacted the warmtiles rep and he said he would ship out a replacement right away. Amazing! Thanks all.
Lucas
Unread 05-31-2011, 09:52 AM   #6
One thing I did long ago was install a whole-house surge suppressor at the power panel. Now, it isn't the greatest one (there are much more significant ones available), but on the expensive stuff, I have plug-in ones that significantly augment the whole-house system. To do this right, you need two CB slots, one for each leg, and (ideally) nothing else connected to those CB except the device. On my HVAC system, I have a device that monitors the line voltage for over/under voltage and will prevent it from running if the voltage is out of range. It also imposes a delay upon power up to allow the line voltage to stabilize. Think about the surges when the power company restores power and every house goes from no load to a significant one (especially where a/c is in use!). It can make those first seconds and maybe even minutes really messy.
Power fluctuations can be a cumulative thing...lots of smaller hits can be as bad as one big one. The whole house thing prevents spikes from appearing in the house, sometimes from internal things like pumps, or other motors, and definately from outside. Nothing will protect you from a major lightning strike, but some precautions are cost effective for the more common power problems.
Unread 05-31-2011, 10:56 AM   #7
lnb001
So does this mean everytime my power goes out the thermostat will be ruined? Will it matter if I try to make sure the tstat is off if I think there will be a power outage?
Lucas
Unread 05-31-2011, 03:34 PM   #8
Every power outage is different...and, some devices can handle surge or transients better than others. IMHO, it is prudent to help mitigate those things in the whole house and really concentrate on the expensive stuff with dedicated protection (things like say the computer, TV, stereo). Keep in mind that many appliances these days are controlled via computer(s). It can get really expensive to trash say that microwave or stove or refrigerator that finally dies. The junctions in solid state material can get 'chipped' away by spikes. Just like hitting a boulder with a small hammer, eventually, you turn it into sand. I prefer to replace those things on my schedule, not theirs, and to do that, power conditioning helps.
It could have been a fluke on your thermostat that coincided with the power outage. Infant mortality can strike anything for any reason. Some designs are better than others...without a post-mortem, there's no way to tell if it was a fluke, infant mortality, or a design flaw.
warm tiles walt415 Tile Forum/Advice Board 3 12-02-2010 05:22 PM
Easyheat Warm Tiles, Redgard, and SLC goboilers Tile Forum/Advice Board 3 11-23-2009 10:48 AM
Schluter and Warm Tiles Mat 02turbo Tile Forum/Advice Board 1 04-02-2009 09:01 PM
Warm Tiles problem sergv Tile Forum/Advice Board 5 06-05-2006 07:43 AM
Warm Tiles Jholmes9 Tile Forum/Advice Board 4 12-17-2004 01:10 AM
