Unread 04-24-2009, 04:28 PM   #1
Gritz
Cleaning and causes of water stains on granite?
I know these areas around my bathroom and kitchen sinks are caused by our water which is well water but we have a water softener, so why is it happening and is there a product I can use to clean it? Thank you!
Gritz is offline   Reply With Quote
Unread 04-24-2009, 11:05 PM   #2
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
It is most likely the salts from the softener and some other waterborne minerals manifesting themselves. You can scrape it off with a sharp razor blade without harming the granite. You have Verde Butterfly, and a mild vinegar solution on that particular stone will be fine too.
Once you have it cleaned up good, a weekly cleaning with a good spray cleaner like the 3-in-1 from GranQuartz will make future clean-up a little easier.
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Unread 04-25-2009, 01:18 PM   #3
Gritz
Thank you for your reply, going to work on it now. Is the vinegar solution 50/50 with water? And is the solution also safe on Uba Tuba granite?
Robin
Unread 04-25-2009, 01:55 PM   #4
Davestone
Florida Tile & Stone Man
You can use it full strength if needed,and the Uba Tuba will be fine also.but always test in an unseen area first.True granites aren't harmed by most household acids other than hydoflouric.
http://Davestonestile.com
Water stains or etching on granite tiles/mold too? Sue_Bee Cleaning, Restoration and Sealing 7 03-08-2008 08:25 AM
Cleaning Hard Water Stains Mike126 Cleaning, Restoration and Sealing 3 01-23-2008 05:17 PM
Water stains on granite tile hiredgun58 Cleaning, Restoration and Sealing 8 01-09-2008 09:18 PM
Water stains (I think) on beige marble floor CinLoo Cleaning, Restoration and Sealing 1 03-16-2005 02:38 PM
Water stains on marble counter Tom in Phoenix Cleaning, Restoration and Sealing 9 07-27-2004 09:09 PM
