Unread 09-17-2008, 07:22 PM   #1
David Meiland
Stone sealer drips on CI tub...?
Customer alerted me today to some very faint drips on a new Kohler cast iron tub. The tub is in a slate deck with a limestone backsplash, and the stone was sealed after the tub was set. The installer used an Aqua-Mix sealer, I believe Enrich 'n Seal. It appears that some drops of the sealer hit the inside of the tub near the rim and ran down. It is barely visible but it's there. The owner cleaned the tub with Soft Scrub, and that's all that's been done so far, aside from me scraping at it with my thumbnail.
Is there anything that dissolves sealers like this?
David Meiland is offline   Reply With Quote
Unread 09-17-2008, 07:31 PM   #2
Davestone
Florida Tile & Stone Man
You might try this....http://www.aquamix.com/products/pg_d...2462&pgid=9833
http://Davestonestile.com
Unread 09-17-2008, 07:36 PM   #3
The Kid
The Kid's Avatar
Try using a little of the same sealer on a scrub pad. It should reemulsify the sealer in question and wipe right off.
The Kid is offline   Reply With Quote
Unread 09-17-2008, 07:38 PM   #4
Mike2
David, I found this on their website. Aqua Mix recommends 3 products for removal of Enrich 'N' Seal.
Sealer and Coating Remover that Dave links to above
Heavy Duty Tile & Grout Cleaner
Stone Deep Clean
All of the above are Aqua Mix products. For detailed instructions, here on their website http://www.aquamix.com/resource%5Fce.../#problem29759.
