Unread 02-27-2008, 07:38 AM   #1
Baseballgary
Baseballgary
Slate Walls, Sealers and Grout Releasers
I finally finished installing slate tile on the walls of my first floor bathroom. Now its time to gear up for the grout which can be very labor intensive. I am a little confused about the advice I see within some of the postings on slate and sealers. My understanding is the sealer will not be a huge help releasing the grout from the surface of the slate. I may want to use a grout release. Go slow and work in small areas yes, but the order of applications should be what:
Seal - Grout Release - Grout – Seal Again or
Grout Release - Grout - Seal?
What’s the preferred method toward making it easier to grout a slate wall? Thanks in advance for the help!
Baseballgary is offline   Reply With Quote
Unread 02-27-2008, 08:16 AM   #2
Mike2
Gary, do you ultimately intend to apply an enhancer to your slate? If so, that changes the suggested order of things.
Unread 02-27-2008, 11:28 AM   #3
Baseballgary
Baseballgary
I guess I have not thought of an enhancer, but I would like the slate tile to stand-out since I have put so much time and effort into it.
What would be the application order for the enhancer, sealer, grout and grout release?
