Unread 02-26-2008, 08:16 PM   #1
3pupmom
estimate
We just got an estimate for installing a tub surround, 3x6 white subway tiles, with a 3 inch accent stripe of glass at eye level. The glass would cover 2.5 square feet and the subway tiles would cover 50 square feet. The cost of purchase is approximately $150 for the glass and $250 for the subway tiles. The estimate I received was for $2300. Seems really high to me. Is this the going rate for professional tilers?
Lacie
3pupmom is offline   Reply With Quote
Unread 02-26-2008, 08:45 PM   #2
JTG
JTG's Avatar
Hi Lacie
If that is just to install the tile yes but does the bid also include removal and disposal of the existing and prep of all surfaces to receive new tile?
Where in the country are you located?
My bid would be in that range plus setting materials and wall prep materials.
Good Luck
JTG
Jerry
Santa Seattle
Ballard
Unread 02-26-2008, 09:02 PM   #3
3pupmom
Thanks Jerry,
We are in PA. We demo-ed the bathroom and put up the tile backer ourselves. Seems to be too much, considering.
Thanks for your input.
Lacie
Unread 02-26-2008, 09:13 PM   #4
Deckert
I think its a little high considering you did the demo, and hung the backer.
But keep in mind, I dont live in your area and don't know the market where you live.
Sounds like you already did the tough parts, might as well set the tile your self!
Brannigan
HeenanGC.com
Unread 02-26-2008, 09:16 PM   #5
johntrent
Hi Laci - did you put up any type of moisture barrier behind the underlayment or will the installer be using a membrane or liquid applied waterproofing?
Hard to say without knowing all the details - if you did all the demo & installed the cbu - seems to me you may have the "gumption" needed to tackle the tiling also - you can ask any & all questions you may have here and I promise you - you will get honest answers with enough info to walk you thru a tub hop install....then you can make the decision about whether or not the price was too high....
Just something to think about.
John
johntrent is offline   Reply With Quote
Unread 02-27-2008, 04:54 AM   #6
scuttlebuttrp
Like others are saying; we don't know all the details, so I don't like to comment on others pricing.
It is a good idea to get two or three bids when you hire someone though.
Get a couple more bids, check references, and use the best installer for your situation.
Or try taking a crack at it yourself.
Royce
Unread 02-27-2008, 05:04 AM   #7
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Lacie......Like the others have said, we do not know all the circumstances having not Seen the job. There are a lot of variables.
Here is what I CAN tell you.
Subway tiles are a tedious & Time consuming installation to get a Nice job, particullarly with some brands.
I did not hear what type of Grout you were going to use which is also a variable.....Epoxy grout is more expensive to purchase AND to install. It never requires periodic sealing however and is worth exploring since it will save you alot of effort over the years in cleaning.
So tell me, Are you 50 miles out in the country on a 5 mile long dirt road?
Is this a Second story bathroom and its White carpet all the way from the stairs to the bathroom?
Like I said, Alot of variables and everyone Impacting the bottom line price
Need help with an estimate! Steven Tiler Professionals' Hangout 46 03-06-2009 06:17 AM
i need help with a estimate mike1976 Professionals' Hangout 7 03-11-2008 12:57 PM
$50 for an estimate and getting it jim mclaughlin Professionals' Hangout 12 02-27-2008 11:38 AM
estimate need help opiethetileman Professionals' Hangout 13 11-04-2007 08:14 AM
Estimate or quote? Blackberry Professionals' Hangout 19 10-17-2005 09:47 PM
