Unread 02-25-2008, 11:08 AM   #1
redred
Red face Sanded or unsanded
Just laid my first tile floor - HOORAY! Came out GREAT looking, so far. I intermixed 12" and 3" tiles from different manufacturers. As a result, the grout lines are not completely consistent. (And getting level was real fun, too.)
I'm pretty sure the stock routing is unsanded for less than 1/8" and sanded for over 1/8." Well, I have about 1/8" (or less) mostly, with some over and some under. Which is worse, using unsanded in the larger joints, or trying to stuff sanded into the narrower joints? My untutored inclination is that I need to go sanded and hope for the best in the narrow joints; but, I would like to go with all unsanded unless that will result in cracking from excess shrinkage. I doubt any place has more than 3/16". (I know it's tough to judge without actually seeing it.)
Is there a clear answer on this?
Red in DC
redred is offline   Reply With Quote
Unread 02-25-2008, 11:14 AM   #2
MudGuy
Pass the Mud
MudGuy's Avatar
Red -
From the description of your project, sanded is the plan.
Jonathan
MudGuy is offline   Reply With Quote
Unread 02-25-2008, 02:11 PM   #3
maddfrog
I wouldn't worry too much about having trouble working the sanded into the smaller joints. I had joints that sound a lot like yours on the first floor I did and I didn't have any trouble at all, even though a couple of the joints were less than 1/16". The sand is very fine...
Jamie - DIYer
maddfrog is offline   Reply With Quote
Unread 02-25-2008, 02:28 PM   #4
MudMaker
MudMaker's Avatar
another vote for sanded
mm (aka "Paco")
Unread 02-25-2008, 02:47 PM   #5
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
If some of your joints are more than 1/8", then sanded is your only choice.
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Unread 02-25-2008, 03:57 PM   #6
tilerite
tilerite's Avatar
Yes, sanded for sure.
tilerite is offline   Reply With Quote
Unread 02-25-2008, 05:04 PM   #7
redred
Thumbs up
Thanks, all. On my way......
Red in DC
