Unread 02-21-2008, 01:47 PM   #1
67stang
Advice on adding stone facade to front of house
Maybe this is bordering on masonry rather than tiling, but I suspect the concepts are the same and the pros here can help me.
My home is wrapped in redwood siding - flat, not overlapping.
I want to add a stone (the concrete preformed stuff) facade around the garage. Can I use the same concepts as an interior tiling project... e.g. apply a waterproof barrier like roofing paper, then 1/2" Durock, then mortar the pieces into place?
Something like this, though not as extensive of an area:
http://www.answersingenesis.org/muse...23_masonry.jpg
Chirag
Editor - FordMuscle Magazine
http://www.fordmuscle.com
67stang is offline   Reply With Quote
Unread 02-21-2008, 01:59 PM   #2
RedRock
Granite, Quartz, and Tile Installer
RedRock's Avatar
I did a small job like the one in the picture using durock, mason mix, and Harristone. I don't think the durock had enough surface area to bind the mud and rock together. I'd stick with the traditional lath and scratch coat method.
Yes, a water proof barrier like roofing paper would be advisable.
Juan
__________________________
You are never too old to set another goal or to dream a new dream. - C. S. Lewis
RedRock is offline   Reply With Quote
Unread 02-21-2008, 02:37 PM   #3
poolmaninct
steel mud pipes tiles ....underground
add a footing to the list
Ray
less with the jaw.....more with the paw
poolmaninct is offline   Reply With Quote
