Unread 02-20-2008, 02:20 PM   #1
raetzsch
Alvin's Bathroom Remodel
First, let me say great forum...awesome group that i'm thankful can help me out (hopefully) along the way.
tiling our bathroom floor (tub surround later) and wanted to ask if you guys think i'm doing ok with the subfloor. The area is only ~35 sq ft, and the walking area only ~21.
For joists that are SYP or Douglas Fir, in good condition, 7.25 inches tall, 1.5 inches wide, 24 inches on center, and 8 feet long between supports, the deflection calculated is 0.176 inches.
This translates to a deflection of L / 545.
House built in '35, and the inspector said she couldn't find a variation of greater than 1/2 inch in 1600 sq ft of oak floors, so things sound pretty solid.
There's 1x8 diag planking, and was planning on adding 1/2 inch BC, as instructed by Ditra, which i will be using on the ply.
As the deflectometer says, i should be fine. my only concern is that i'm laying 18 inch tiles...are they that different than 12's, is the deflection data just as valid?
PS: can anyone recommend a place to order the ditra tape (i'm assuming i should use it on a bathroom floor), as HD didn't have any?
Alvin
Columbus, TX
raetzsch is offline   Reply With Quote
Unread 02-20-2008, 03:27 PM   #2
Alvin, there isn't any difference in the structural requirements for big tile, just flatness. You'll want no more variation than 1/8" out of plane in any 10 foot direction. This is to make it easier to set the tiles with little lippage.
Order on-line at www.tile-experts.com.
Unread 02-20-2008, 04:13 PM   #3
Hi Alvin,
What Bob said. If the floor is pretty flat you're in good shape.
Unread 02-20-2008, 05:31 PM   #4
raetzsch
Thanks guys, feel much better now.
So how necessary is banding the ditra together and/or at the walls for a bathroom floor? Does it make a difference in everyday use, or is it as implied in the Ditra manual for unplanned situations such as overflows, etc?
Alvin
Columbus, TX
Unread 02-21-2008, 09:47 AM   #5
Mike2
Alvin, in a typical bathroom waterproofing the floor outside the shower including all the Ditra seams and floor-to-wall connections serves no practical purpose. You could spend a lot of unnecessary time and money doing that only to discover that during an unexpected flood, the water simply flows right through the doorways.
Unread 02-24-2008, 02:01 PM   #6
raetzsch
leveling the subfloor
I've pulled up all the luan and have patched the rotten areas with 3/4 ply, and now have a small problem. The ply is 23/32, and the planks are 3/4 (minimum, may be a 16th or so thicker being old lumber, like all my studs are). What's the best way to level, considering that i'm putting 18" tile down...putting 1/2 ply on this followed by Ditra.
PS: Can someone rename my thread to Alvin's bathroom remodel or the like? Thanks.
Alvin
Columbus, TX
Unread 02-24-2008, 02:09 PM   #7
Well, I would have recommended you use full-length shims on those joists before you installed the plywood, Alvin. Or sistered them to raise the tops enough to make you plywood level. Tough to add an eighth inch to the top of that sheet.
Unread 02-24-2008, 02:13 PM   #8
raetzsch
Thanks CX
Guess i should add that the ply is not screwed down yet
So is that the best way to go? what's easy to find that i can use to shim a 1/16?
Alvin
Columbus, TX
Unread 02-25-2008, 09:06 AM   #9
Didn't notice that it was only a sixteenth, Alvin. Only good shims I know of for that thickness are sheetrock shims. I would maybe take a chance on those if that's not a ground floor, but I generally prefer to scab on some boards to level/flatten anything on a subfloor. Gonna be pretty easy in your situation.
Unread 02-25-2008, 09:33 AM   #10
Maack
Maack's Avatar
Heres an easy way:
Just go get some 15# felt roofing paper,
cut it into strips to lay on top of the joists,
experiment,, make a small test piece of the 3/4" ply,
use 1 layer,,maybe 2 layers of strips, that ought to bring you up 1/16"., tack it down with staples, then just refasten down your 3/4" ply.
make sure your 1x8 sheathing boards are tightly secured down as well before you test your height variances.
Maack
Pro remodeler
N. Virginia
Maack is offline   Reply With Quote
Unread 02-29-2008, 04:30 PM   #11
raetzsch
Toilet flange issue
Got the subfloor down and within 1/8 for the entire bathroom.
Now on to the toilet. I have a 4" CI drain with a lead flange, lead was torn, so need to get it out. Bought one the Oatey expansion flanges that will seal up in the CI, but first I need to get that inner collar out...any best way(s) to get that loose/break it up?
my drain and the oatey expansion flange:
Alvin
Columbus, TX
Unread 03-01-2008, 02:18 PM   #12
raetzsch
bump
Alvin
Columbus, TX
Unread 03-01-2008, 04:10 PM   #13
Maack
Maack's Avatar
Flame....
Typically, a plumber would fire up a MAPP gas torch, heat up that lead and scrape the softened lead down the the top edge of the CI.
You can't do that cause of the wooden floor structure and the risk of fire,
so............
I would simply use a old sharp wood chisel,(when it goes dull on you, just put the edge to a grinder and resharpen it) and keep skimming off thin layers of the lead, lil by lil till your down to the edge of the CI,
looks to me like about an hours worth of hammering and chiseling..
Stuff an old towel down the CI to prevent lead pieces and tools from falling in, and sewer gas from coming up outta that pipe.
Plumbers carry a few old chisels for just such things.
I can't quite tell from the photo, but do you believe you have enough surface of that plywood to have a place to anchor your toilet flange screws into?
hope that helps??
Good luck!
Maack
Pro remodeler
N. Virginia
Unread 03-04-2008, 03:14 PM   #14
raetzsch
Thanks Maack, it's done and sealed.
Layout question. I will have 4 tiles and a 7 inch left over (18 inch tiles) b/w the tub and door. I can obviously shift and have two 12 1/2 inch tiles, one by tub, one by door. Is this the right choice bar none? The tile will be about 1/4 higher than the oak in the hall, so i will have a reducer of some kind at the doorway...just don't know if it will be covering the edge of the tile or not (prefer not, just butting up against it).
Any recommendations?
Alvin
Columbus, TX
Unread 03-04-2008, 03:44 PM   #15
It is always correct to have no cut smaller than one half of a full tile, Alvin. If that doesn't "look" right, do it differently. But that's the industry standard.
I always make my reducers from tile to wood such that they butt up to (but with appropriate gap) the tile and are flush with the top.
