Unread 02-20-2008, 10:44 AM   #1
redred
Question Best way to achieve relief/inset?
I am planning on doing my first tub/shower surround. Going whole hog, will be doing inset panels on all walls, with a complementary tile. I will use backer board (sorry, not up to trying to mud a wall - yet). To get the 1/4" relief I want, is it best to put up 1/4" on the whole wall, and then another 1/4" on the parts I want raised (all around the sides/edges/corners), to there is a single "unit" to it? Or is it OK to use 1/2" at the outsides and use completely seperate 1/4" for the inset areas?? (Or do I need to go back to my tile book and be reminded that I need a minimum 1/2" backer board on all framing in any event - even 12" framing as I have in this case, so I don't really have a question here?)
Thanks.
Red in DC
redred is offline   Reply With Quote
Unread 02-25-2008, 10:59 AM   #2
redred
Red face
Starting this weekend, if anyone can offer advice.
Red in DC
Unread 02-25-2008, 11:45 AM   #3
are you trying to have some of the tile stand out raised on an area of the wall ?
I doubt you can install 1/2" in some area's and 1/4" in another due to stud placement.
I would do 1/2" all over and install 1/4" in the area you want to stand out.
JMO
Unread 02-25-2008, 12:11 PM   #4
conceptsplus
Conceptsplus- Randy Gilmore
conceptsplus's Avatar
Yes, go 1/2" then 1/4" over the 1/2" where you need it. Thinset the 1/4" over the 1/2".
I make straight edges and notch the ends to screed off thinset when building out things like glass tile, etc. It seems to me the layers of cbu may screw with water drainage in the walls, especially if it's red garded.
Randy Gilmore
Natural Stone Contractor - Springfield, Missouri
Website needs updates- be back soon.
conceptsplus is offline   Reply With Quote
Unread 03-02-2008, 09:40 AM   #5
redred
Thanks. I'll do it that way.
Red in DC
