Unread 02-19-2008, 08:12 PM   #1
Rich_Bybee
Lifespan of a diamond saw blade?
Hi All,
I'm wondering if this is normal.
I've cut about 100 linear feet of 5/16" porcelain tile and I'm down to bare steel on my 10" felker diamond saw blade (this is the stock blade that came with the saw).
I honestly figured the blade would last longer, but I have no idea if this is normal or not.
Any ideas?
Oh, can diamond saw blades be re-diamonded? or just go buy a new one?
Rich
Rich_Bybee is offline   Reply With Quote
Unread 02-19-2008, 08:22 PM   #2
stonemason777
Try running blade thru brick or pumice stone
stonemason777 is offline   Reply With Quote
Unread 02-19-2008, 08:50 PM   #3
PrecisionFlooring
Custom Hard Surfaces
If its anything like the stock blade on a TM-75 it was probably bare metal to begin with
Try dressing it and see if that helps, if not a new blade is in order
Paul
Do it right or don't do it at all....
PrecisionFlooring is offline   Reply With Quote
Unread 02-19-2008, 10:25 PM   #4
lefty33
lefty33
new blade
if you are down to bare metal it is time for a new one. I have used several brands and you should get thousands of feet cut with a new quality blade
lefty33 is offline   Reply With Quote
Unread 02-19-2008, 10:41 PM   #5
Rich_Bybee
Thanks guys,
This was the factory blade with a FTS-150, so it is probably similar to the blade that comes with the TM-75.
I really am down to bare metal as far as I can tell. So I don't think dressing it will help.
If I should be able to get 1000's of cut feet per blade, then this one REALLY sucks!!
Any recommendations for a "good" brand of blade? Are any "good" brands available at HD, lowes, or Ace? I hate to halt this project to wait for shipping. :-(
Unread 02-19-2008, 10:51 PM   #6
Rich_Bybee
Oh, btw, this is why I think the blade is shot. Maybe someone can tell me if my thinking is wrong....
I cut two pieces of bullnose tonight and everthing worked great! I then went to put a piece of the 13" through the saw and all of a sudden the blade was throwing up sparks! I checked for obstructions, and there were none. I'm not cutting in to the table. There was no loose tile in the space for the table, just sparks every time I tried to cut.
I checked the edge of the blade, and as far as I can tell, it is bare metal.
Unread 02-19-2008, 11:01 PM   #7
Steve in PA
Tile Contractor/ Installer
Steve in PA's Avatar
Hi Rich
Here is a good 10" blade for Porcelain... ($54)
http://www.constructioncomplete.com/...erTM710in.html
I bought 2 around 6 months ago. The first one is still cutting true after moderate to heavy use.
Steve
Steve in PA is offline   Reply With Quote
Unread 02-19-2008, 11:22 PM   #8
MudGuy
Pass the Mud
MudGuy's Avatar
Hi Rich -
Very happy with Diamond Products - Heavy Duty Orange. I buy them for both my wetsaw (10") and my grinder (4"). Used this company for years.
Here's their website to find out who distributes in your area.
www.diamondproducts.com
Jonathan
MudGuy is offline   Reply With Quote
Unread 02-19-2008, 11:31 PM   #9
yes your blade is shot, the side might have meat on it still but the end is dead.
Unread 02-20-2008, 05:23 AM   #10
scuttlebuttrp
Felker's normal blades are good. MK Gold has always been an awesome blade. I only use a Dewalt blade on my grinder and love them. Don't know if they make a bigger one for your saw though.
Whatever you do though, don't talk to that guy on the phone who calls everyone. He's a real hemmeroid.
Royce
Unread 02-20-2008, 10:17 AM   #11
Mike2
Rich, were you using that blade wet or dry to cut that first 100 feet?
Unread 02-20-2008, 11:42 AM   #12
Rich_Bybee
Thanks all!
Mike, I was cutting wet.
Unread 02-20-2008, 11:56 AM   #13
Mike2
Thanks.
I had to ask because a blade's life-span measured at 100 LF is unusually short. Even for a stock blade that is shipped with a new saw.
Unread 02-20-2008, 01:17 PM   #14
Rich_Bybee
Could the fact that I was cutting 5/16" porcelain explain the short lifespan?
Unread 02-20-2008, 08:05 PM   #15
Mike2
Without being there or even seeing a picture of this blade, all we can do is guess. Really guess and to that end my guess is cutting porcelain would in itself not explain the short life span. Yes, porcelain is very hard but not very abrasive. To go through the entire diamond matrix on a blade with 100 LF of cutting suggests me me a very abrasive material was being cut or a deflective blade that slipped past quality control.
Or to put it another way, I can't explain it. Not even a clue.
