Unread 01-29-2003, 07:33 PM   #1
birdman
Unhappy rookie mistake???
hello board..my first time..be gentle..
total renovation of my bathroom..down to studs..used durock for shower walls and floors, and just found out I may have installed the durock it upside down!!
my question is for installing tumbled marble (4"x4") on durock with modified latex thin set does the textured side of the durock have to be used, or can i leave it the way i have it with the smooth side up and tile away?? please help!!
P.S. I have seen some post regarding the Bonsal shower pan..I am using it for my shower pan and will let everyone know any pros or cons.
birdman
birdman is offline   Reply With Quote
Unread 01-29-2003, 07:45 PM   #2
Jason_Butler
Tile Setter
The CBU is the same composition throughout even though one side has a bit more texture than the other.
Although I have not made this "mistake", I see little harm in the use of the "slick" side. You will need to make sure the thinset is troweled into the board to ensure a good bond is formed.
If you really want to be sure, take a piece of scrap tile and thinset it to the "slick" side of some scrap CBU. Check the bond after 4-5hrs . I would expect it to hold quite well.
Jason
Unread 01-29-2003, 08:16 PM   #3
Hi Birdman, Welcome.
It just doesn't matter, as Jason has indicated. Cement sticks to cement. Forget it.
Now, give us a first name, will ya? I don't want to call you Bird. My parrots will get jealous.
Unread 01-30-2003, 03:02 AM   #4
Sonnie Layne
Da Poet
Bird,
I don't know why, and it seems counterproductive to me, that all CBU mfg's specify their smooth side toward the tile (outside). Seems to me the inside would allow for more traction/surface area.
I suspect it is highly likely because of the dust that settles on their product while being shipped palletized over long distances and the way it's laid on the pallet. The dust left on the lower surface can settle down into the tiny indentures and possibly allow a release area. I'd say as long as everything is wiped out, or sprayed down to dampen it, you'd end up with a better bond on the rough side. On the other hand, I didn't write the warranty.
I'd say you'll be fine either way. Moistening the substrate never hurts no matter what you're using.
Sonnie Layne is offline   Reply With Quote
Unread 01-30-2003, 04:21 PM   #5
birdman
thanks for the help!!
first name dave...i'll keep you posted on the project.
Unread 01-30-2003, 04:56 PM   #6
davem
davem's Avatar
And don't forget pichers Dave, we all like to look at pichers.
davem is online now   Reply With Quote
