Unread 01-26-2003, 01:21 PM   #1
Mark R DIY
8 x 10 wall tile question
Has anyone ever seen an arrow, possible indicating up or down
on the back of a tile?On the back is also the size, country of origin,
and the letters "T4" and "01". The finished side is a matte finish.
And if you are holding the tile looking at the back and reading the
info described above, this arrow points down???????????????
Mark R DIY is offline   Reply With Quote
Unread 01-26-2003, 01:44 PM   #2
K_Tile
Member of Million SF Club!!
There are directional tiles out there. Azuvi comes to mind. Can't really tell you which way is right, check with the supplier to find out if you have one. You can also lay them out on the floor and see if the printed design on the face should match up. Which way is the arrow facing toward the 8" or the 10" side?
Unread 01-26-2003, 02:10 PM   #3
It might be there so you can rotate the tiles to achieve a random pattern. (arrows in adjacent tile point the opposite way)
