Unread 01-15-2003, 03:10 AM   #1
eman
Guest
Posts: n/a
PEI Rating
We're about to have our Kitchen and Dinette floors done in Ceramic tile. We've narrowed down our choices to two tiles. The tiles are from a local carpet and tile store and one says made in spain the other made in Turkey on the back. There is no indication as to what company in Spain made the first tile except for a sticker on the face of the tile that reads "Transtar Distributors" and the name of the tile "Natura Blanco". The saleswoman at the store tells me this tile has a PEI rating of 4 and they charge $1.69/ square foot. The tile made in Turkey is also a PEI 4 according to our salesperson and sells for $1.29/ square foot. My question is, how do I verify the PEI rating for myself. Neither tile is porcelain as it is not the same color throughout. Either tile would look well in our kitchen and are very similar, with the tile made in Turkey just a shade darker than the Spanish tile. I've noticed the tile made in Spain has dark red middle and bottom, whereas the tile made in Turkey, although not Porcelain, appears to have a slightly darker yet similar color to its surface color. The reason I'm telling you this is we can't seem to decide which tile to go with as they are similar in appearance and would both compliment the kitchen. I'm trying to decide based upon other criteria. I should add the tile from Turkey has a gritty feel to its surface, the tile from Spain a smoother (but not slippery) surface. Any opinions on all this would be greatly appreciated.
Unread 01-15-2003, 06:00 AM   #2
Garrett
The PEI rating and other technical information should be on the tile box, probably in the language of the country where the tile is made. I would also check the website of the tile manufacturer and send them an email.
Pete
"There is nothing common about common sense."------Voltaire
Garrett is offline   Reply With Quote
Unread 01-15-2003, 07:24 AM   #3
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Sounds like one is a monicoturra and one is porcelanite.Either would be plenty good for a residential application.
Unread 01-15-2003, 09:06 AM   #4
Dave Gobis
da Man!
Dave Gobis's Avatar
OK, tell me why? You know a lesson is coming!
Unread 01-15-2003, 09:53 AM   #5
flatfloor
"da Leveler"
flatfloor's Avatar
Just posting this so I follow it. I wanna lesson.
Jim Buckley
Tile Calculator
New Here? Read this!
Unread 01-15-2003, 11:28 AM   #6
eman
Guest
Posts: n/a
Monicoturra or Porcelanite - advantages of one over another ?
First off, thank you all for your replies. They have been very helpful. I assume form the term porcelanite that the ceramic tile that appears to have a similar color throughtout, but it's not porcelain, is the porcelanite. Therefore the tile with red clay under the decorative top is the monocoturra. I've searched these terms on the web, but was unable to determine if the porcelanite has any durability advantages over the other. I should have added one other criteria. The Monocoturra tile has wavy uneven edges, whereas the porcelanite tile has straight edges. I beleive my wife is leaning towards the monocoturra tile because of its wavy edges (adds character) and because it feels a bit smoother than the porcelanite. Any further thoughts ?
Unread 01-15-2003, 12:50 PM   #7
Dave Gobis
da Man!
Dave Gobis's Avatar
OK, as long as your curious, I will give the lesson now. The body of the tile has nothing to do with the glaze rating. The test method has no effect on the body. Doesn't make any difference whether it is porcelain or terracotta. Porosity, Breaking Strength, and Modulus of Rupture and Elasticity are indicative of the body properties. The "PEI" is a glaze wear rating, period. Once you glaze a porcelain you have glazed tile. The body may have stronger properties but glaze is glaze.
Unread 01-15-2003, 05:02 PM   #8
Garrett
But is there not a direct and positive correlation between a PEI rating and the quality of the substrate. Curious minds want to know.
Pete
Unread 01-15-2003, 06:02 PM   #9
Dave Gobis
da Man!
Dave Gobis's Avatar
Nope, it is just a glaze rating. Want me to send John a picture of the test machine? File said it was too big for me to attach. It is used for ISO and ANSI standards. The only thing relevant to substrate is the requirement that a ceramic tile have a minimum of 250# breaking strength. On wood you need it, over concrete you could get by with less. Most porcelain tile comes in around 375 to 400#.
Unread 01-15-2003, 07:57 PM   #10
eman
Guest
Posts: n/a
uneven tile edges
I've got just one more dilemma now that I know that either tile should perform well. The tile we are probably going to have installed has wavy uneven edges, the other tile has normal straight edges. Does anyone have any positives or negatives about those uneven tile edges ?
Unread 01-15-2003, 08:21 PM   #11
tileguytodd
Now you know Dave I always appreciate a lesson !!
It would be nice to know for sure cause Playing the odds i bet i'm at least 1/2 right
Lets take the forinstance that they went to a mom and pop store looking for a floor tile.This eliminates all wall tile and being a mom and pop store and the area being used i would venture they would show them appropriate tiles.Most red backed tiles appropriate for this area in the shop i work out of right now are a monicoturra type. The other inexpensive floor tile most prevelant that would suit these areas is a porcelanite . Now granted there may be a few true percelains out there at good prices,but the promos of the last 2 years in our shop have been 95% the 2 above types.So,while I can always use a lesson or 2 or 3,I still am in touch with the product being sold right now, today , In the retail market.I do spend some time in the shop.I am not always on the computer you know
By the way , your not related to the TileRanger are you
Unread 01-15-2003, 09:26 PM   #12
Dave Gobis
da Man!
Dave Gobis's Avatar
The point was the body is not related to the wear rating. I picked up some test samples for show and tell last week of glazed porcelain that hardly made residential. By the way, it was advertised as a 4 when in fact it was a 2. It is a combination of factors that make a quality tile. All I was trying to say is it is prudent to consider all factors when selecting tile.
Unread 01-15-2003, 10:20 PM   #13
Hi Eman, Welcome.
Seems our experts got off on a tangent here.
Fact is, either of the types of tiles you are interested in will be perfect for you, as long as your wife likes it.
The surface is what we're concerned with (so long as the underbody will support the surface), so a PEI of 3 or better is fine.
Unread 01-15-2003, 10:31 PM   #14
Jason_Butler
Tile Setter
In addition to John's advice, I'll comment on the edging of each tile.
The tile with the uneven edges is less stressfull to install if you are concerned about keeping all of the grout lines straight.
On the other hand, if you are a perfectionist, the uneven edges will drive you crazy. The straight edged tiles make it easier to follow a control line and the use of spacers with such tiles is also beneficial.
As a wise man said, the best tile is the one that please the wife
I think that was a line from John's book
In terms of quality, the edges mean nothing..
Jason
Unread 01-16-2003, 08:15 AM   #15
tileguytodd
I knew that dave, I just saw opportunity to finally stick my tongue out at ya !!
OK gotta go to work now.Hope your healing up Dave.
And ,Your still the Man!!!!
