Unread 01-13-2003, 02:22 PM   #1
flyjetta
Cool Tiling over concrete
I did a search, but didn't find anything. I currently have linoleum over concrete in my bathroom. If I lift it up and am able to get all the adhesive off and the concrete isn't cracked at all, is level, with no high or low marks.. can I just begin to tile? Or do I still need to put something down first??
flyjetta is offline   Reply With Quote
Unread 01-13-2003, 02:34 PM   #2
Derek & Jacqui
Send a message via MSN to Derek & Jacqui
Yes you can
DEREK & JACQUI
NULLI SECONDUS
IMPOSSIBLE DONE IMMEDIATELY, MIRACLES TAKE A LITTLE LONGER
Derek & Jacqui is offline   Reply With Quote
Unread 01-13-2003, 02:50 PM   #3
flyjetta
ok.. on to my second question. If I tile an area, then rip up the cupboards in that room and replace them with new ones that aren't the same size.. can I add on to an existing tile floor?
Unread 01-13-2003, 03:05 PM   #4
drew
Remodeler, North-Central Missouri
As to your second ?, yeah you probablly could do it that way, but seems like that would be going about it the hard way.
Jim Drewery
House Docs
Salisbury, MO.
All you need in this life is ignorance and confidence, and then success is sure.
Mark Twain
drew is offline   Reply With Quote
Unread 01-13-2003, 03:33 PM   #5
flyjetta
the second question is only if I decide to replace them sometime down the road..
Unread 01-13-2003, 05:53 PM   #6
Jason_Butler
Tile Setter
If you think you may remove/replace the cabinets in the near future, go a lil' light on the thinset in these areas. It will make life easier when you do the replacements.
Jason
