Unread 01-10-2003, 05:30 PM   #1
derrhon
Send a message via Yahoo to derrhon
shower door install?
Everyone,
I have another question, imagine that.
I am stalling a swing arm door on the shower I am building. My questions relates to when I should attach the door. Should I install in over the tile or before I tile?
Regards,
Derrick
derrhon is offline   Reply With Quote
Unread 01-10-2003, 05:41 PM   #2
K_Tile
Member of Million SF Club!!
Over the tile.
Make sure the walls are plumb and you have a stud to screw into. Dont rely on the wall and molly ancors to hold it up.
Unread 01-10-2003, 05:56 PM   #3
derrhon
Ok, over the tile.
Do you cut the holes for the screws after the tile is layed?
or
Do you cut holes in the tile where you think the screws will be before you lay the tile?
I did put a stud behid so I am OK with that. I am just worred about the tile cracking.
Regards,
Derrick
Unread 01-10-2003, 06:06 PM   #4
K_Tile
Use a masonry drill bit to drill through the tiles. Then screw the door through the properly located holes. Do this after the tile as set up.
Unread 01-10-2003, 07:26 PM   #5
Derrick,
It sounds like this might be a long project. You might find it helpful to keep your questions on one thread. That way everybody will be up to speed on what you're doing. Just a suggestion. It's up to you.
Unread 01-10-2003, 11:35 PM   #6
tomtuttle
Official Brau Meister, JB Forums -- Tacoma, Wa.
tomtuttle's Avatar
Try to hit the grout lines
When I installed my shower door, I discovered that it was practically impossible to drill through the porcelain without a diamond drill bit, which I was unwilling to buy for this one job. I drilled new holes in the door mounting hardware, aligning them with the grout lines. No problem.
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
tomtuttle is offline   Reply With Quote
Unread 01-13-2003, 01:11 PM   #7
Ash Langton
Ash Langton's Avatar
I'm at this stage of shower door installation and was wondering if these diamond glass drill bits would cut holes in porcelain tile for the mounting screws? This is the link to the ebay site.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3105887711
Thanks, ash
Ash Langton is offline   Reply With Quote
Unread 01-15-2003, 08:25 PM   #8
Sparky
Lightbulb Frameless Shower Installation article
Derrick,
I don't know if you're doing a frameless shower,
but this feature article from the Dec. 2000 issue of
the Journal of Light Construction may be helpful:
http://www.jlconline.com/cgi-bin/jlc.../View/0012show
If the above URL does not work, go to
and type in
Frameless Shower
into the web site's Search function.
Good luck with your project.
Sparky is offline   Reply With Quote
Unread 01-15-2003, 08:31 PM   #9
Sparky
Thumbs up This Old House Article
Derrick,
Here's an article from the This Old House web site:
Installing a Shower Door
Contractor Rich Rosenfield's step-by-step guide to creating a tempered-glass enclosure.
http://www.thisoldhouse.com/toh/home...214441,00.html
