Unread 01-09-2003, 10:15 PM   #1
mahnrut
grout at joint again
I tried to find a posting where someone said that an economical way to seal the gap between a wall tile and a granite counter is to grout it and then remove some of the grout at a 45 degree angle and caulk the gap. Is this correct as I am just about to ask our tiler to do that. I think he is planning to grout this joint.
Barbara
mahnrut is offline   Reply With Quote
Unread 01-09-2003, 10:58 PM   #2
Jason_Butler
Tile Setter
That joint will most likely crack at some time . A color matched sanded caulk would proabably work better since it would remain flexible
Jason
Unread 01-10-2003, 12:11 AM   #3
Bill Vincent
Tile Contractor
Bill Vincent's Avatar
Jason's absolutely right, but DON'T let your contractor grout it first. Reason being, that if you grout first, you lose the "anchor" for the caulk. With just a skim coat of caulk on top, sooner or later, it's going to peel off.
Unread 01-10-2003, 07:22 AM   #4
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Actually Bill, that sanded caulk sticks to damn near anything and someday if you want to remove it,you'll find out you'l wish you had one of those genies in a bottle
If he grouted it,dont fret to much.Sanded caulk is(as monty python would say) And now for something completely differant
