Unread 03-10-2007, 08:43 AM   #1
JAG1569
Slate On Concrete Front Porch
Just starting and have a few questions. Porch is 6' X 35', concrete with brick borders. I want to install slate so which kind do I buy, honed or guaged? Do I need to use backerboard and felt? ( the porch is over a crawl space so the slab does not touch the ground ) There is a small settling crack that I need to repair but I need to know what product to use for this application. Also, which grout is best? thanks, Jerry
JAG1569 is offline   Reply With Quote
Unread 03-10-2007, 09:03 AM   #2
Hi Jerry, Welcome aboard.
I'm curious about the structure -- reinforced concrete over a crawl space. I don't think I've ever run into that in residential. In any case, no backerboard. You could use a membrane such as Schluter Ditra. http://www.schluter.com
Unread 03-10-2007, 09:17 AM   #3
ddmoit
ddmoit's Avatar
Might look something like this, John. This was a rental unit I owned. It had a concrete porch with a crawl space you could access from the basement.
Dan - a DIYer in SE Tennessee
Unread 03-10-2007, 09:38 AM   #4
Welcome, Jerry.
We had us one of those a while back, JB. I think that one was pre-stressed concrete panels over concrete/block walls and you could actually walk under part of it. front was kinda like that picher Dan posted with a walk-up, I think. Got noooo eye-dee how to find it, though. And no eye-dee what we tole that fella to do with his, neither.
If it's already got cracks, you've got some considerations there. Any of the cracks higher on one side than the other?
And if you're in a freeze/thaw region, you might wanna re-think that slate. This porch is open to the weather?
Those are two completely different characteristics of the material, Jerry. I'll let one of our Stoners 'splain that, though.
Unread 03-10-2007, 09:47 AM   #5
JAG1569
Yes, it looks like that. Cape Cod style.[IMG]\\rrhs01-207486\users\jerryg\My Documents\My Pictures\136 HIDDEN LAKE[/IMG] maybe it came through...
Unread 03-10-2007, 09:52 AM   #6
JAG1569
yeah, we're in north Georgia so there is some freezing. It is open to the weather. What would be a better choice of materials? crack is small, 1/8" and even on both sides.
Unread 03-11-2007, 05:57 PM   #7
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
Unless you can find a really good quality, fully metamorphosed slate (you will most likely NOT find this at Lowes or Home Depot), I would suggest you look for a slate look porcelain tile.
The stuff you buy at the big boxes are most often geologic shales and are not good for use anywhere they could get wet or exposed to wide temperature changes.
A dense, hard slate - similar to what they would use for roofing purposes - would be an OK choice for your porch.
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
