Unread 03-09-2007, 03:32 PM   #1
AMIRCHEL
(un)Timely tub/shower redo
I've gutted my 1938/1980 main upstairs bathroom to the joists. I'm OK for ceramic tile according to the Deflectometer. Still need to rip up a few of the patched areas of subflooring. After reading and reflecting, here are my most pressing questions: 1. replacing the tub/shower with a new tub/shower in the same position in the alcove. Do I seal the plastic to the tub lip or leave it laying behind the Durock (or whatever you suggest I use)? 2. what kind of insulation do I use? 3. I think Ditra will best isolate any water on the floor--how do you seal the joint between tub and floor/ditra? just use silicone? 4. Should there be 1 more layer of underlayment outside the tub, so the tub is 'sunken' from the floor? And how many layers and what thickness of plywood over the joists? 5. I have to tile the ceiling of the alcove--what do you suggest for backerboard--same as walls? 6. I've been told you can stick just about any vent/light in the tub/shower ceiling...any suggestions of makes--do I have to have a 'wet certified' product? Thanks in advance for your answers, and thanks right now for providing such a forum. It's been a tremendous resource for me.
Andy
AMIRCHEL is offline   Reply With Quote
Unread 03-09-2007, 07:28 PM   #2
Scottish Tile and Stone
Andy, Im a bit confused.
You say to seal the pastic to the tub lip. Do you mean a vapor barrier on the walls?
Are your walls standard 2x4's? Just get insulation for 2x4 walls. I think it should be R12?
Shouldnt have to seal the ditra on the floor to the side of the tub. When you install the tile, the thinset will be right next to the tub.
You shouldnt need anymore plywood unless you need to stiffen the floor, but you already said you meet deflecto requirements.
yes same as walls on ceiling.
Yep you need a vent or light suitable for a wet location..
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Unread 03-10-2007, 10:46 AM   #3
AMIRCHEL
Thanks for the speedy reply, Scott. Sorry about the confusion--let me clear it up. I'm ready to start rebuilding and need to get my supplies, especially for the subfloor and underlayment (if needed). 1. yes, I meant the 4mil plastic vapor barrier--siliconed to the tub lip --OK. 2. with the vapor barrier, then I use UNFACED insulation, correct? Also , do I vapor barrier on the ceiling? 3. ok 4. i am down to the joists. What is recommended for a. subfloor-- OSB or plywood? (5/8"-3/4" or something like Sturdiwood, if I can find it?) b.underlayment, assuming I use Ditra over it--1/2" plywood enough? 5. just subfloor under tub(porcelain on steel), or subfloor+underlayment? 6. what's easiest/best to use on the walls and ceiling in the tub/shower alcove? Durock or do you suggest something else? Again, thanks...
Andy
Unread 03-10-2007, 11:28 AM   #4
Hi Andy, Welcome aboard.
You don't need to seal the vapor barrier to the tub. Just let it come down all the way and sort of roll onto the tub, hand the backer board and then trim off the excess vapor barrier. You don't want or need it on the ceiling.
If you can't get unfaced insulation, slash the paper face with a rasor blade.
If you want to waterproof the floor, thin set strips of Kerdi-band over the Ditra seams. Use silicone to seal the Ditra to the front of the tub.
Unread 03-11-2007, 06:15 AM   #5
AMIRCHEL
Thanks, John for the welcome and the info. I still need some feedback about setting the tub -- on just (new 5/8"-3/4") subfloor, or subfloor+underlayment? Does it make sense to ditra under the tub, maybe then cover with 1/4" CBU or plywood? Pretty nice day today -- and I'll be inside testing the supply lines and starting the subflooring
Andy
Unread 03-26-2007, 02:17 PM   #6
AMIRCHEL
Exclamation Bathroom redux -- joist impass
Finally attacked the one weak floor joist in my 6'x10' bathroom. It has a huge notch (for the tub drain) and was half-muled sistered with a few short lengths of 2x4 on top of 2x4s. The joist was so weak the I couldn't just pry the 2x4s out---cut the nails thru with my saw-z. Once the sisters were out I could see a fairly large split through at about half the length of the joist. YIKES. I propose to remedy this by 1. glue/epoxy/clamp joist 2. use matched size 2x8 to sister like crazy 3. block wherever I can, again using 2x8s. My wife used to joke about the floor in the bath being so weak she wouldn't be surprised if someone ended up in the kitchen below. Truth not so far from that--it's almost like the ceiling was supporting the joist. No wonder they had a mud floor in there.
So, please advise if my game plan seems sound...I really don't know what else to do. Perplexed but determined...
Andy
Unread 05-05-2008, 01:30 PM   #7
AMIRCHEL
It's been over a year and I am finally starting to cross brace my sistered joists. I recall reading in a post a method for cutting cross-blocks accurate to fit between joists...I am having trouble getting a proper fit, i.e. a block that slides in without pounding or gaps. Can anyone advise me further on this? Thanks...
Andy
Unread 05-05-2008, 02:25 PM   #8
Measure twice, cut once?
Are your joists twisted or cupped? Have you considered joist hangers?
Unread 05-06-2008, 11:45 AM   #9
AMIRCHEL
YES, old house. I don't want to create problems. Just thought there might be a handy trick to figure the angles. If both adjacent joists are a little off it is very difficult to measure/fit accurately. My guess is to use one of those adjustable arm things to get the angle for each joist off level, measure the top width than transfer each angle. Time-consuming but should work. Thanks
Andy
Unread 05-06-2008, 01:07 PM   #10
Use joist hangers, and then cut your blocking to the minimum spacing. You won't have to be so darned picky.
Unread 03-01-2010, 04:12 PM   #11
AMIRCHEL
I just checked back on my original postings to this site and 3 years have already passed since my initial demo. The bride and I are tired of, more like fed up with, sharing our master bath. Most prep work done, which turned out to be extensive. Help me move on please...plan to cover walls with 6ml, and seal to tub lip. Question #1--I recall being advised NOT to put the barrier on the ceiling--is that correct? There is a suitable vent light in the middle of the tub/shower alcove ceiling, so moisture removal will be greatly improved. Question #2--if walls are covered with plastic that is sealed to tub edge followed by cement board plus tile--which will get sealed to the tub with silicone--how in the world will moisture in the cement board drain out? More like it's trapped and can only go up, or back out through the tiles. Makes more sense to Redguard, but need advice. Question #3--tub snug in alcove, level along length but slanted slightly into room. Can I just shim the outer part of tub, or must I SLC the tub area? (In)Sanity beckons...
Andy
Unread 03-01-2010, 04:46 PM   #12
Brian in San Diego
Brian in San Diego's Avatar
Andy,
Threads never grow to old to resurrect around here. I merged your new thread with the original so we have the background information. I'll change the title to your new title as soon as I'm finished here.
You are correct in questioning where the water goes and the short answer is "back the way in came in". Many people believe when you caulk that bottom row of tile to the tub surround that you leave a weep hole at both ends of the horizontal run so moisture can escape through there. RedGard is another viable option but considerably more expensive than 6 mil poly. I like the idea of surface applied membranes (whether sheet or liquid) because the water never makes it to the substrate.
Unread 03-02-2010, 01:09 PM   #13
AMIRCHEL
Brian--thanks for bringing my old threads back from the dead. My floors are solid, as level as I could get them. But not perfect. My immediate focus is the tub---it slants slightly down from the outside long wall toward the inside of the room, maybe only 1/16th of an inch. If it needs to be perfectly level, can I just shim with a layer or so of roofing felt (or whatever material)? If not, then SLC? Level is good the length of tub...
Andy
Unread 03-02-2010, 01:33 PM   #14
Brian in San Diego
Andy,
Is this a new tub you are installing? I am not a tub expert by any stretch but I do read here a lot. Most tubs are set in a bed of mortar and my assumption is that ther can be leveles at that time. If it's existing I think I would be tempted to leave it. You may be able to shim it but I wonder if it's worth the effort. Maybe someone has a different idea.
Unread 03-02-2010, 02:33 PM   #15
AMIRCHEL
Brian, The tub is a new Americast Princeton, enamel on steel. Support is by 2 X 4 underside on the long wall and by it's opposite side on the floor, held in by the next layer of underlayment. No bedding required or suggested. I'll await further responses...here's a link to the tub--->http://www.americanstandard-us.com/b...gral-overflow/
Andy
1/2 shower redo dpbj6 Professionals' Hangout 8 07-30-2007 09:51 AM
Tub surround redo sjsmithjr Tile Forum/Advice Board 2 04-27-2006 07:43 AM
A timely question? iDesign Professionals' Hangout 12 04-23-2006 01:44 PM
tub dias (or deck) redo Boe Tile Forum/Advice Board 9 05-28-2003 06:28 AM
newbie-redo of tub/shower and surround sawzall Tile Forum/Advice Board 5 11-27-2002 06:50 AM
