Unread 03-06-2007, 06:21 PM   #1
Jholmes9
Floor sloping to drain - general stragegies?
Okay, so my tilesetting experience consists of one shower, one small bathroom floor, one tiny backsplash for a pedastal sink in said bathroom, and one hearth for a woodburning stove. So far, so good. Now my brother wants to move his laundry from his cave-like basement to an available room on the second floor. In anticipation of the day that something goes wrong and a lot of water hits the floor in that second-floor laundry, he'd like to put in a tile floor and slope it towards a drain. Of course, he'd like my help with this. What might be the best way to achieve the slope and the drain in such a situation? Should it be done like a typical shower preslope (of which I've read but not done) or can anyone suggest an easier way?
Jholmes9 is offline   Reply With Quote
Unread 03-06-2007, 06:35 PM   #2
ddmoit
ddmoit's Avatar
I'm not qualified to answer your question, but I do have a comment. I think it would be much easier and cheaper to greatly minimize the chance of that leak ever happening. Start with a front loader washer that holds a lot less water than a traditional top loader. Set the washer in a specially designed pan, in case it does leak. Use the best hoses you can, and replace them on schedule. With these steps in place, I'd say a leak is no more likely than a leaking copper pipe in an interior wall.
That's what I would tell my brother.
And then I would help him build his floor with drain.
Dan - a DIYer in SE Tennessee
Unread 03-06-2007, 07:16 PM   #3
MudMaker
MudMaker's Avatar
Mr. Holmes,
Gotta first name we can use? pewt it in the UserCP above under edit signature..
I'm with Dan on this - I've seen pans under the washers with drains.. Cheap insurance...
mm (aka "Paco")
Unread 03-07-2007, 08:43 AM   #4
Jholmes9
Thanks for the thoughts so far. Hmmm...
Are these pans a mass-produced item or something you'd make?
A flat floor would certainly be easier to deal with.
--Jon
Unread 03-07-2007, 12:50 PM   #5
Mike2
They are mass produced and available for $20 or so. Oatey makes one without a drain fitting http://plumbing.hardwarestore.com/52...an-624516.aspx . Harvey has one with a 1" pipe fitting for a drain line http://www.wmharvey.com/prod/cat12/p...ashing_pan.php.
I'm betting most washing machine appliance stores either have in stock or could order one up for you. Lowes, Home Depot, ???
Unread 03-07-2007, 01:20 PM   #6
irish tileguy in michigan
Tile Contractor -- S.E. Michigan
irish tileguy in michigan's Avatar
These pans are designed just for washing machines, lowes and home depot sells them. if your brother is still nervous go with ditra under your tile.
Steve
Maloney Tile and Marble
Farmington Hills & Livonia, Mi.
Laticrete Hydroban & Schluter Kerdi shower installs
Custom installation of Tile and stone
irish tileguy in michigan is offline   Reply With Quote
