Unread 02-27-2007, 11:24 PM   #1
Mr. Overkill
Mr. Overkill's Avatar
discolored marble at grout joint
Hi all, its me again
I grouted the marble around my fireplace and it looks like the color in the grout soaked into the marble. I tried to seal the marble before grouting but being vertical I wasn't able to soak the marble like tile on the floor.
Is there a to remidy this isore?
The pictures don't show the discoloration at the grout joint as well as I see it standing in the room.
-David
"I am always ready to learn, but I do not always like being taught."
— Winston Churchill
Mr. Overkill is offline   Reply With Quote
Unread 02-27-2007, 11:32 PM   #2
Jason_Butler
Tile Setter
I assume you just grouted?
If so, give it a few days for everything to dry out. That discoloration looks more like moisture than pigment. Hard to tell though.
As an aside, the first granite tile work i did had a big "problem" with discoloration about 30 minutes after setting. I freaked. Didn't sleep all night either.
Showed up the next day and all was well. The moisture from the thinset had absorbed into the tile. Looked fine after drying
Jason
Unread 02-27-2007, 11:42 PM   #3
Mr. Overkill
I was hoping it was moisture also when I first noticed it.
It has been almost 2 days now since I grouted - I think the moisture is gone.
-David
— Winston Churchill
Unread 02-27-2007, 11:44 PM   #4
Mr. Overkill
I'm still hoping for a miracle tho
-David
— Winston Churchill
Unread 02-28-2007, 06:56 AM   #5
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
The moisture might take longer to migrate through the tile because you sealed it
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Unread 02-28-2007, 09:25 AM   #6
Mike2
Yea, give it some more time David. I've experienced discoloration looking similar to that just from cutting the tile on a wet saw. No grout involved.
Unread 03-01-2007, 02:15 PM   #7
Mr. Overkill
What is the longest I should wait before ripping out my hair?
-David
— Winston Churchill
Unread 03-01-2007, 02:38 PM   #8
thydroc
A saying we use here at work is, "Hard telling, not knowing."
Drink a beer and wait a few months. No sense stressing about it now, it is what it is.
Call me Todd
thydroc is offline   Reply With Quote
Unread 03-01-2007, 04:59 PM   #9
My granite tile took over a week to dry out. Give it a chance. the moisture takes awhile to move through the tile. You could place a fan in front of it and the air movement would speed it up some if you want. It looks like you used a cement based grout, but if it was a pre-mixed one, it might have stained things.
Unread 03-01-2007, 05:56 PM   #10
Lazarus
Lazarus's Avatar
Could be a week or two. Patience, Grasshopper!
Laz...
Unread 03-01-2007, 09:35 PM   #11
Mr. Overkill
Thanks for all your replies.
Today, I finally noticed a differance. It looks like it is drying out and going back to the natural color.
I am now.
-David
— Winston Churchill
