Unread 01-06-2003, 03:27 PM   #1
Sparks98
Send a message via AIM to Sparks98
shower complete! Can I seal floor?
Thanks to all on this board for helping me do a pretty much pro job on my shower. It is a 4X3 base all done in tumbled marble with 1x1's on the floor, which drains PERFECTLY as you said it would. I've sealed the heck out of the walls and ceiling with Aqua Mix Pro Solv 10 Stone Sealer. I experimented with alot and found it best, even over the water base stuff. Can I seal the floor? It is the area most likely to be stained. I will post pictures shortly.
Sparks98 is offline   Reply With Quote
Unread 01-06-2003, 03:50 PM   #2
e3
Guest
Posts: n/a
yes that same product may be used on the floor of a shower. follow manf. written directions
Unread 01-06-2003, 08:31 PM   #3
Hi Sparks,
Yes, is the sealer is moisture transmissible, you can use it on the floor. I have an aversion to using waterproof sealers on shower floors because they lock in moisture.
Hey, how about a picture?
