Unread 01-05-2003, 07:41 PM   #1
t_wall
Tiling on Cement . . .?
Happy New Year all, I've appreciated all the advice I've already gotten from this forum.
We are wondering how to approach tiling our laundry room, which is on a different slab than the rest of the house. It's basically a cement floor with (very old) vinyl tiles stuck on top.
Some of the vinyl tiles have cracked over the years, and small pieces are missing. Should we remove all the old vinyl and adhesive and try to put some type of subfloor down before tiling, or leave the remaining vinyl, level as best we can, and tile on top?
Or, is it even possible to attach subflooring to a slab?
Thanks for any suggestions.
Terri
t_wall is offline   Reply With Quote
Unread 01-05-2003, 08:43 PM   #2
Jason_Butler
Tile Setter
Pull up the vinyl, clean the adhesive off with a scraper and some Jasco adhesive remover, then begin tilin'
I'm not really sure what kinda' subfloor you would use over a slab or why you would want something other than the existing slab. Once the VCT ( Vinyl Composition tile) comes up and the adhesive is removed, you have an excellent surface for tile.
Check for cracks as well and let us know before you begin.
Jason
