03-19-2006, 09:13 AM
Tiles against the wall
Hi,
Like to put some tiles against the wall. The section is about 5 feet long and 3 feet high.
The wall is drywall. Do I need to put some plywood up in order to tile this ? Or does it need wood and then backerboard before I can tile this ?
The tiles are probably gonna be the 'normal' standard 4x4 ceramic tiles.
Thank you
03-19-2006, 09:24 AM
Licensed Remodeling GC
is it in a shower or tub area? if not go ahead and tile right over drywall might want to rough up paint a little first though
03-19-2006, 09:29 AM
Thank you, Kevin!
03-19-2006, 09:32 AM
Welcome aboard, Coffee.
03-19-2006, 09:36 AM
Thank you!
My name is Danny.
Will visit this Forum often, since I have some projects to do...
03-19-2006, 01:07 PM
To 'just' put tiles up against the wall, do I use a mastic ?
A pre-mix adhesive ?
03-19-2006, 01:21 PM
If it's dry
If it is an area that you are sure will never get wet, then mastic will work fine.
-Ron
03-19-2006, 01:24 PM
Thank you, Ron.
I appreciate the speedy reply!
03-19-2006, 02:35 PM
Hello -
Can a mix of ceramic and glass tiles be put on drywall in a kitchen backsplash? It's mostly ceramic subway tiles with glass mosaic accents (3 glass pieces at each short end of subway) Thank you
Carla
03-19-2006, 06:17 PM
yes but the mortar for glass will have to be used on the ceramocs as well becasue glass is thinner than ceramic. use highly modified mortar like megaflex
03-19-2006, 07:45 PM
I use 'flexbond' modified thinset for mosaics that have tile and glass and mirror. I usually glue two pieces of glass together before setting to get the height up. I've never had a problem, even on the floor. I'll post a photo tomorrow when I get home.
Jerimiah
03-20-2006, 12:39 PM
here the pic i promised, this is on regular hardibacker with regular modified thinset. the glass is doubled like mentioned. I have another simular on my frontporch walkway that takes lots of abuse and no problems.
Jerimiah
