Unread 11-17-2004, 05:57 PM   #1
belle1012tk
cut outlet hole in tile
I just built a tile hearth for my wood stove. I am just stumped on how to put a outlet hole in one tile then i will be done. is it possible to put a hole in a tile. thank you...
belle1012tk is offline   Reply With Quote
Unread 11-17-2004, 06:00 PM   #2
sean riha
sean riha's Avatar
it's totally possible. how big of a hole do you need?
sean riha is offline   Reply With Quote
Unread 11-17-2004, 06:01 PM   #3
Rd Tile
Tile Man
Rd Tile's Avatar
Yes, is the outlet hole completely in the tile?
An angle grinder with a diamond blade blade will do it.
Unread 11-17-2004, 07:11 PM   #4
Mike2
Sean, I’m ghosting here as RD’s graphical artist.
Using the grinder w/4” diamond blade per his recommendation above, cut into the tile as much as you can without overrunning onto the exposed surface of the tile. Do this on the backside as well. Those triangle pieces will snap right outta there.
Unread 11-25-2006, 03:48 PM   #5
NightWind
NightWind's Avatar
What about a diamond jig saw blade or perhaps putting a diamond blade on a chop/ miter saw, would that work?
That's my story and I'm sticking to it. Trish
NightWind is offline   Reply With Quote
Unread 11-25-2006, 07:23 PM   #6
Hi Trish,
The smaller diameter grinder blade will do it better and easier.
I don't know of anyone makes diamond jig saw blades. I think they would overheat easily.
Unread 11-25-2006, 10:45 PM   #7
mkrosen
Might I also suggest...
Dremel works well for cut-outs.
~ Mary
mkrosen is offline   Reply With Quote
Unread 05-25-2007, 08:32 PM   #8
tile mom
I once used the coolest jig saw. It had a diamond blade, I guess, and used water...you could've cut a scroll with that saw. Really Nice. cut beautiful circles, any shape at all. I wish that I had one. Anyone know where to buy one?
Memmy
tile mom is offline   Reply With Quote
Unread 04-25-2012, 10:50 AM   #9
Windwood
Windwood's Avatar
I once had a situation where I needed to cut a register hole in a 24"x24" porcelain tile and the tiles kept breaking, so, I marked my cut and glued the tile in place and then made the cut out using my right angle grinder with diamond wheel and a shop vac to catch the dust and debris. It worked perfectly.
Windwood is offline   Reply With Quote
