Unread 11-01-2004, 05:27 PM   #1
ninemile
Tile Saw Goddess
ninemile's Avatar
Lightbulb Ideas for scrap 3cm thick granite pieces that I can get for next to nothing
I was at my Granite fabricator today to drop off some porcelain for bull nosing. I noticed their ever growing pile of cast off pieces from granite slab fabrication and asked what they did with them. Basically nothing was the response, take some if you want.
I grabbed some pieces, most of which are about the size of my hand or larger. All polished for slab use, 3cm (1.125") thick, some real beauties.
So, my question is what could I use this material for? They had marble too, but granite is some much more stable.
I do have a 15 x16 patio I'm going to be doing at my house next spring which will start as a cement slab with ditra. I had been planning a fancy geometric cut tile pattern which is basically 100% of what I do, but thought maybe the granite could be used. Any idears???
Colleen Staton
Geometric Tile &
Nine Mile Properties, LLC
ninemile is offline   Reply With Quote
Unread 11-01-2004, 05:44 PM   #2
Davestone
Florida Tile & Stone Man
Might make some neat chessboards. That's all i got.
http://Davestonestile.com
Unread 11-01-2004, 06:37 PM   #3
Steven Hauser
STT Owner
Steven Hauser's Avatar
rubble, lots and lots of rubble.
Maybe a mosaicist or two wants the stuff.
Clean
Sealed
Safe
STT Sealers with Attitude!®
Unread 11-01-2004, 07:23 PM   #4
I grab slab sink cut-outs whenever I can. I know a slab guy that says they save them for a while then just toss them in the dumpster when they need the room. I have made several small tables from them, got a bunch of cut-outs in my garage gathering dust.
Unread 11-01-2004, 07:38 PM   #5
rob 223
My garage is packed full of this sort of stuff that just seems to nice to throw in a landfill. I need to start finding people who would use it. I like the chess board idea! Havnt played that game for years, its funny that when I play for fun without a strong desire to win that is the only time I win, the more I want to win the more mistakes I make.
rob 223 is offline   Reply With Quote
Unread 11-01-2004, 07:43 PM   #6
doitright
doitright's Avatar
I knew a fabricator that was collecting the pieces in 55 gal. drums. His idea was to put them into a concrete driveway, grind, and ???? Maybe enhance. I don't know if he ever actually pulled that one off.
The larger pieces were cut into usable rectangles, and installed on his office & showroom floor. Quite colorful I might add!
John Koessler
Unread 11-01-2004, 09:23 PM   #7
ninemile
Tile Saw Goddess
ninemile's Avatar
I did just talk to one of my customers about using it for their fireplace surround instead of the slate they wanted to use. They loved the idea. I told them that they'd have to go to the yard and pick out the pieces with me!
John, I used to save all my porcelain scrap pieces from my cut tile jobs like your fabricator. Trouble is I got to much of them so I'm starting to just dump em.
Did the fabricator use 3cm thick pieces for his floor?
Colleen Staton
Geometric Tile &
Unread 11-01-2004, 10:03 PM   #8
Pogie bate, Colleen. Don't mess with the fabricator. Go to the distributor, somebody like IGM or one of the other big guys, Walker-Zanger maybe. These guys drop slabs on the floor pretty regularly and throw them in the dumpster. Big pieces, baby.
Unread 11-01-2004, 10:13 PM   #9
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Break the pieces up with a hammer and do a randon floor or a random coffee table/end table set.grout joints from 1/8" to 3/4" ,sanded grout, multicolored granite pieces and a light colored grout. after the grout cures,Polish the entire thing and seal it.Save your leftover thinset on each job at the end of the day in a freezer bag.when you get home,set a few pieces with the thinset thats already mixed.Throw away the baggie.before you know it you'll have a nice table set
so hows that for an idea Colleen?
Random might be hard for you seeing as your used to geometrics.
Random had no rhyme or reason.
Unread 11-01-2004, 10:33 PM   #10
doitright
doitright's Avatar
Hi Colleen
This was done when 2cm and laminating edges was popular. I think he wound up dumping his barrels also.
I like Todd's idea. Only thing is it sounds like a lot of work.
John Koessler
Unread 11-01-2004, 10:37 PM   #11
tileguytodd
John, have you seen colleens geometric floors??
For her, piece of cake
Unread 11-02-2004, 02:08 AM   #12
Trask
Oregon Tile Man
Trask's Avatar
I did a driveway apron & patio out of these and have been saving up to do my whole drive. I cut them into a "step Pattern" one small 1 7/8 square and one larger 4 7/8" square. I keep a gate set up at the shop on my 'purgatory 'MK and a bucket near by. Every now and again I have a cold one after work and cut a few feet. When I get a bunch I tumble them W/ sand and water in an old cement mixer, that has had the paddles removed. Makes nice pavers but takes lots o time. They also need to be wet set as they vary in thickness. I think I will set the edge pieces out of 3cm and make a deeper bed like you would a footing.
Long on ideas and short on time don't let it become work
Unread 11-02-2004, 07:33 AM   #13
RandyL
Tile Setter
Send a message via Yahoo to RandyL
Colleen...........how about cutting them into circles and making coasters for mugs and stuff. Get some felt at a fabric place to glue to the bottom. What do ya think?
GID'DAY!
I FEAR NO BEER! (except Grolsh....yuck)
RandyL is offline   Reply With Quote
Unread 11-02-2004, 01:36 PM   #14
Albert
Albert's Avatar
Location: trailer in cajun country wiff edna (sometimes)
i wood takem to a river and skippem across the water. them flat sides makem skip reel good.
albert
Albert is offline   Reply With Quote
Unread 11-02-2004, 04:15 PM   #15
Steven Hauser
STT Owner
dems rele dnese stuff. Theys don skip theys sink.
We tried it.
Clean
Sealed
Safe
