Unread 07-09-2004, 02:58 PM   #1
30all
a good diamond drill bit
a good diamond drill bit (1/4") is needed quick for parcelain tiles,
my old one from www.diamond-drill-bit-and-tool.com shot after not to many holes (rpm may have been too high).
any one can recommend a good source to order?
-andy
30all is offline   Reply With Quote
Unread 07-09-2004, 03:46 PM   #2
ConstructionComplete.com
ConstructionComplete.com's Avatar
Thumbs up Tile / Porcelain Drill Bits
Hello,
Just a quick response to confirm that there is now porcelain drill bits available on the market. These bits are good for ceramic, marble and glass as well, but are strong enough to drill the toughest tile!
Click here for more info:
http://www.constructioncomplete.com/...DrillBits.html
ConstructionComplete.com is offline   Reply With Quote
Unread 07-09-2004, 04:17 PM   #3
Mike2
Thanks for the info Joe (I'm assuming that's you behind the CC post). Re. the 3/4" and larger core bits - are these for both wet and dry use?
Unread 07-09-2004, 06:25 PM   #4
30all
anyone used this bit before? I was dispointed by 1/4" the diamond core drill bit I got before, it did not last long to justify $20+ a piece.
I checked the link, the prices are stiff but I'd buy if they worth it.
how many holes will a bit last? how fast can they drill through hardest 3/8" thick parcelain tiles? I have too many to drill.
-Andy
Unread 07-09-2004, 10:23 PM   #5
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Ive never seen a 20.00 drill bit that was worth buying as far as drilling floor tile.
75.00 on the low end for a small bit is a more realistic price for a quality bit that will last through many jobs.
Good Core bits will drill through concrete, stone etc and last many years.A good core bit set of 1" 1 1/4" 1 1/2" 2" 3" 4" is a hefty investment well over 1 thousand dollars.Add the 1/2" increments and the 5 and 6" and you are into several thousand dollars.
Unread 07-10-2004, 12:59 AM   #6
Gil Smith
$55 does sound a little steep for a 1/4" carbide bit......I could see it if they were diamond. What makes these carbides so special? They don't look that much different than the $6 ones at HD........
Gil Smith is offline   Reply With Quote
Unread 07-10-2004, 01:57 AM   #7
branty1uk
Brit Tiler
branty1uk's Avatar
Send a message via MSN to branty1uk
I cant believe the price of the felker TM 75 $310 that works out at about £160. We can only get Rubi cutters here and their samilar saw is the diamant dt-250 at £870. Contruction complete havent put any shipping on, that cant be right.
Danny
I never forget a face..........................but in your case, I'll make an exception. Groucho Marks
branty1uk is offline   Reply With Quote
Unread 07-10-2004, 08:35 AM   #8
Porcelain drill bits
I want to confirm that we have had great feedback from our customers on these drill bits. We have been told by the manufacturer that they are the only type of its' kind on the market. A small indent must be made in the tile to keep the bit centered, but once they get going they last pretty long. A cooling agent (water , oil) is a good idea to extend the bit life.
Please feel free to call us on Monday to dicuss further if you would like. Thanks! 800-889-0661
Rick
Unread 07-10-2004, 09:14 AM   #9
Jason_Butler
Tile Setter
After cutting numerous holes for faucets, I would be very interested in low end core drilling setup. This would work wonders for drilling precision holes in stone, porcelain, etc.
Any ideas?
Jason
Unread 07-10-2004, 09:53 AM   #10
Core drill bits
Hello,
Basically there are 2 options for your application. For the drilling of basic core holes through ceramic and marble can can buy the bits below individually:
http://www.constructioncomplete.com/...ramicTile.html
But for granite and procelain (the hard stones) you would need to buy a kit like the one below:
http://www.constructioncomplete.com/...inePTCKIT.html
Please let me know if we can help further. Thanks!
Rick
Unread 07-10-2004, 12:18 PM   #11
Taylor
Taylor's Avatar
Diamond hole saw?
http://www.contractorsdirect.com/cgi...tools/DHS.html
Taylor is offline   Reply With Quote
Unread 08-02-2004, 11:45 AM   #12
30all
tried the Pro Line bits
Spent about $50 for a 1/4" Pro Line bit, this bit is make in England, It looks very high tech.
If you need the feedback about how it worked on the porcelain tiles I have, PM me.
-Andy
Unread 08-02-2004, 12:01 PM   #13
genel
genel's Avatar
I am going to be looking for bits to drill porcelain tile in a few months. I am curious as to how well these worked.
Just a house nut.
genel is offline   Reply With Quote
Unread 08-02-2004, 02:05 PM   #14
jgleason
jgleason's Avatar
I bought a diamond core bit from these guys:
http://www.ukam.com/electroplated_core_drills.html
I found the site from a post on this forum a while back. My experience is with the 1" bit. It worked fine, drilled appr. 15 holes through porcelain tile. Plenty of life left in the bit. cost was about $50.
Unread 08-02-2004, 06:31 PM   #15
The manufacturers of the PTC bits were kind enough to send me a couple to try out. They are fabulous, and I'll post a picture or two in a minute. I might be the guy who sicked them on Construction Complete. I wouldn't have done it, Rick and Joe, if I didn't think they are great products.
We built a dam around the intended hole with plumber's putty. We chucked the bit into a humongous Milwaukee drill motor and let the weight of the tool do most of the work. Might have pushed down just a little, but not much. You don't want to force the bit, or you'll ruin it.
