Unread 01-16-2022, 07:59 PM   #1
Sabrexr15
Diverter Gap
Hello All,
I cut out the hole for the diverter. What do you use to fill in the gap?
Barry
Sabrexr15 is offline   Reply With Quote
Unread 01-17-2022, 08:39 AM   #2
Hi Berry,
Looks like the gap between the Hydro Ban foam board and the diverter body is too wide to use their sealer/adhesive to fill it. I'd recommend that you use a strip of Hydro Ban sheet membrane band, cut carefully to follow the curved contour. Affix the band to the HB board with thinset mortar then seal the edge of the band to the body with sealant/adhesive.
Is this the same shower as in this thread? https://www.johnbridge.com/vbulletin...d.php?t=131848
Unread 01-17-2022, 10:26 AM   #3
Sabrexr15
No Sir
this is a just the shower project i am working on.
I will apply the membrane
thanks for the clear direction
Barry
Unread 01-17-2022, 03:22 PM   #4
Sabrexr15
I looked at it again and its only 1/4" gap at the top and 1/8" on the side.
The HydroBan sealant should fill this right?
Barry
Unread 01-17-2022, 10:00 PM   #5
Snets
Professional Weekend Warrior
Snets's Avatar
How does your valve trim cover that gap? Most valve trims provide some type of seal incorporated on the back side of the trim. Many shower valves require a hole with lots of gap to access replacement parts.
Did the valve manufacturer specify the hole in tile/backer dimensions?
Moen 3372 Diverter Valve Mike1324 Tile Forum/Advice Board 7 06-28-2018 10:15 AM
Diverter trim problem hocbry30 Tile Forum/Advice Board 17 09-02-2014 10:35 PM
Built-in Diverter Valve Tyl0r Tile Forum/Advice Board 4 02-22-2011 02:30 PM
Plumbing help - Tub diverter sticking? umichteach Tile Forum/Advice Board 4 09-18-2007 05:34 AM
Any economical diverter valves? And other questions... john2777 Tile Forum/Advice Board 12 12-27-2006 11:23 AM
