Go Back   Ceramic Tile Advice Forums - John Bridge Ceramic Tile > Tile & Stone Forums > Reference Liberry :-)
Closed Thread
Unread 10-19-2021, 11:12 AM   #1
Metropolitan Ceramics
Since this thread has popped back up I'll chime in. I was in charge of looking into the tightened OSHA rules for contractors when I was at MAPEI a few years ago and have to deal with OSHA regulations for my factory now. Some points to keep in mind:
Silicosis is a real thing and you should wear a respirator or use HEPA dust collection if you're generating respirable, crystalline silica dust.
Respirable silica dust is really small, typically not the visible dust you kick up at a job site
Products that don't contain crystalline silica won't cause silicosis. There are mortars and grouts available now that don't. Tile and stone only do if you dry grind/cut them.
Silicosis develops due to repeated exposure over a long duration, generally decades.
There are limits out there considered safe and testing can be conducted to determine if you are above or below them during a certain activity
Educate yourself, protect yourself!
Dan Marvin - VP of Operations
www.ironrock.com
Metropolitan Ceramics is offline
Unread 10-19-2021, 03:16 PM   #2
Related Thread
Dan Marvin was responding to this thread in the Advice Forum about the subject of Silicosis that has popped back up a few times over the years. The links in his post may be of use to others concerned about the subject.
His first link is to a Department of Labor, OSHA, publication of unknown date.
His second link is an article from the NTCA's Tile Letter of June 2018.
cx is offline
Closed Thread
HTML code is On
Worried about silicosis Getat151 Tile Forum/Advice Board 17 11-01-2021 02:18 PM
