Unread 03-29-2020, 03:36 PM   #1
txbatson
Water Droplet Mark Grey Porcelain Tile
We purchased classic gray polished porcelain tile and had a local installer install it. We are noticing darker gray spots from water on the tile. I took one of the left over tiles and put a large droplet of water on it and let it set. After wiping the very light white film off the mark, the underside is is a darker gray circle. Trying to clean with water and vinegar didn't address. I know there are other ways of cleaning but can someone explain how this is happening. Will some other form of cleaning fix this? Is it a defect in the tile. Can porcelain tile can be porous and have this staining under the glaze?
Glenn
txbatson is offline   Reply With Quote
Unread 03-29-2020, 04:00 PM   #2
txbatson
Answering part of my question but now what to do!
So just read the below. I had looked up porcelain tile and it said that it didn't need to be sealed. I didn't realize I needed to designate polished. Sigh. So to elaborate more this was clean water. We live in College Station, Texas which is supposed to have soft water. The water was straight from the tap and clear when I made the droplet.
So what can we do now. If we seal over these spots I assume they will be there forever. If we want to get rid of them do we have to rip up spotted tile and replace?
Found Online
Polished porcelain needs to be sealed with a good impreganator sealer. I use Fila porcelain impreg sealer, lay the tiles, give the the full floor a good coat of impreg sealer then grout. Reason you seal polished porcelain is that the polishing process open millions of tiny hols in the tile surface and dirt and grime can get into them and cause dulling. Matt porcelain needs sealing too.
Glenn
Unread 03-29-2020, 04:52 PM   #3
I can't say why this happened for sure but we have seen this on the forum before. Folks have posted pictures of dark shades in showers, usually near the bottom where water has soaked in from the back side turning the clay bisque darker and it showing thru the glaze. All glazed tiles are not equal. Can you share what brand these tiles are and where they are made? I've only seen this once myself and those tiles were Incepa brand which are made in Brazil.
Unread 03-29-2020, 09:25 PM   #4
Does hitting the spot with a hair dryer for a few minutes cause the spot to vanish?
Unread 03-31-2020, 10:40 AM   #5
"Polished" porcelain should always be sealed before grouting, and some folks seal it right out of the box. Polishing in this case means grinding the surface, which opens up microscopic cavities in the body of the tiles. So your surface, then, is pitted. I don't know how to completely cure the problem.
Help!! Water Marks on Polished Porcelain Silva1992 Cleaning, Restoration and Sealing 4 01-28-2020 02:30 PM
Water stain on sealed porcelain tile Roger3125 Cleaning, Restoration and Sealing 9 08-05-2009 07:14 PM
See Picture Newbie Used Grey Thinset - Granite Stain or Water surfceo Tile Forum/Advice Board 4 04-20-2009 06:57 PM
honed porcelain tile water spots jb1978234 Cleaning, Restoration and Sealing 5 04-07-2009 07:18 AM
cut tile turned grey from being wet jgfons Professionals' Hangout 6 03-18-2005 06:05 AM
