Unread 01-24-2020, 03:56 PM   #1
Badger2Nole
Cleaning metal scraping
Hi all,
Just bought a house with thick, hard soap scum on the shower floor. If been using a metal scraper to remove it, but it’s leaving gray, metallic scrapes on the tile. What should I use to clean it...a baking soda paste or something else. TIA.
Diana
Badger2Nole is offline   Reply With Quote
Unread 01-24-2020, 04:16 PM   #2
Gozo
I’ve used a low scratch scouring powder like BonAmi or Barkeeper’s Friend.
Jeff
Unread 01-24-2020, 09:39 PM   #3
Welcome to the forum, Diana.
Agreed. Bar Keepers Friend (only the powder, not the liquid gel) has worked every time for “metal marks” for me.
It only takes a few seconds of light rubbing to remove the marks.
Unread 01-24-2020, 09:57 PM   #4
Badger2Nole
Great - I’ve got some of that. Thanks to you both!
Diana
Unread 01-25-2020, 10:03 AM   #5
Next time you need to remove some soap scum, you can use a high alkaline cleaner like AquaMix Heavy-Duty Grout and Tile Cleaner. Most any box store that sells tile will have a high alkaline cleaner that will work.
You completely wet the surface, allow to dwell 5-7 minutes, scrub with a nylon bristle brush, then wet vac or rinse away the mess. Repeat as needed. And be sure to neutralize the pH level with a rinse of clean water when you’re done.
Cutback-Ready to give up scraping waj Tile Forum/Advice Board 19 12-12-2012 02:33 PM
Cutback Adhesive Scraping Keneo Tile Forum/Advice Board 16 01-20-2011 07:14 AM
Scraping up old tile from a slab floor rtbrick Tile Forum/Advice Board 12 12-26-2009 04:08 PM
Found cutback on plywood...any way to avoid scraping it? thefed17 Tile Forum/Advice Board 6 12-15-2008 10:33 PM
Scraping thinset for days nearmain Tile Forum/Advice Board 7 09-01-2002 10:28 AM
