Unread 08-06-2019, 02:12 PM   #1
DoRight
what Trowel
I wish to use 1 inch square natural stone in a shower over pan with Kerdi membrane. What knotch trowel should I use? It seems that the larger the trowel the more thinset that seems to get pushed up between the mosaic type tiles and requires a careful eye to get clean and the time to clean out the grout groove. I am probably doing something wrong. Anyway. what trowel for easiest and safest install.
Bob
DoRight is offline   Reply With Quote
Unread 08-06-2019, 07:02 PM   #2
Hi, Bob.
A V-notch is less messy than a square-notch for little mosaics. Maybe you want to give a 1/4” V-notch a try.
Unread 08-07-2019, 05:55 AM   #3
How thick are the 1" tiles, Bob?
Unread 08-07-2019, 08:49 AM   #4
DoRight
The tiles are .39 inches thick. Which has to help with the squeeze up between the tile.
Bob
Unread 08-07-2019, 12:28 PM   #5
Like Bubba suggested then. The 1/4" V notch will probably do the trick.
I used a 1/4X1/4 square notch with my 2X2X3/8 and it worked really well. Yours being only 1X1's a little less mortar under them will be better. You might even try a 5/16X3/16 V notch.
Unread 08-07-2019, 09:53 PM   #6
Elkski
Elkski's Avatar
How wet the mortar is has a big influence on how easily it will squeeze up into the joints. And you want it wet enough that it will adhere good but dryer as long as it's mixed to spec and you get good coverage when you try to pull them off will squeeze up much less in the joints. I've actually started weighing my powder and measuring my water additions to my thinset. It has helped me.
Teddy
Unread 08-08-2019, 07:51 PM   #7
Check your walls with a straight edge and get them as flat as you can before you ever start spreading thinset. If the 1/4 inch v-notch leaves too much thinset mashing thru the joints, go with a 3/16 v-notch. Using a flat piece of plywood or marble to slightly press on the tiles will help get the tiles flat.
your best trowel simpson Tile Forum/Advice Board 19 08-28-2008 07:49 PM
1 Eye, 1 Trowel ! rep56 Professionals' Hangout 22 01-31-2008 11:59 AM
Where's the trowel? DoIt3Times Professionals' Hangout 8 12-07-2007 03:33 PM
Best trowel used to wet set RexModeling Professionals' Hangout 13 03-31-2006 11:31 AM
Trowel Help? K.Carr Tile Forum/Advice Board 5 11-14-2002 05:51 PM
