Unread 08-05-2019, 09:02 AM   #1
rudyrock
Modifying Kerdi niche
Hi All
New to the forum, although have been lurking and learning for some time..great site.
Im a DIY guy that has hit a small snag in my shower stall install.
Bought a schluter niche 12x20" thinking it would fit the stud bays... nope... too many pipes and studs in the way.
So i'm thinking of moving a stud over a bit (non bearing wall) cutting down the niche to 10 1/2" wide so it will fit. Looked around the site for a while and couldn't find an exact answer. I am thinking of cutting the piece out and gluing together with some kerdi fix and then using K band over the cut on front and back.
Will that work? I know schluter won't warranty; no biggie for me and the placement will be on the wall that holds the shower valve so no direct water spray. Thx in advance for advice.
Rudy
Rudy
rudyrock is offline   Reply With Quote
Unread 08-05-2019, 09:07 AM   #2
Welcome, Rudy.
I see no reason why that wouldn't work, but I'd still recommend returning the Schluter niche if it doesn't fit your application and simply making your own niche within the confines of your structure as needed.
Unread 08-06-2019, 08:01 AM   #3
rudyrock
Smile Modifying Kerdi niche
Thx JB I'll build one
Rudy
Unread 08-10-2019, 11:04 AM   #4
Tiger Mountain Tile Inc
It works. I like to fill it up with water when done to check it but it works.
Jim Upton
DIYTileGuy
Unread 08-12-2019, 01:30 PM   #5
JoeDubya
Did you have any luck adjusting your shelf that comes with the 12x20? Mine is loose fit with the product in the box but I cannot figure out how to mount it inside the niche and keep it from sliding down....
Joe
JoeDubya is offline   Reply With Quote
Unread 08-12-2019, 05:37 PM   #6
Trask
Oregon Tile Man
Trask's Avatar
Hey Rudy !
We have done a lot of Kerdi board science projects in the past few years -
And Customized many Schluter Niches as well .
I’ve worked with several Schluter Reps and they didn’t blink at all so long as
We have correctly overlapped Kerdi/band in the process .
Let me see if I can dig up some pics
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Unread 08-12-2019, 06:18 PM   #7
JoeDubya
Wow so just banding it in place is enough to hold a big bottle of shampoo for example on the upper shelf?
Joe
Unread 08-13-2019, 06:30 AM   #8
RichVT
Vermont Remodeling Contractor
The shelf in a niche is normally supported by the tiles on the sides and back of the niche that are below the shelf.
Rich
RichVT is online now   Reply With Quote
Unread 08-13-2019, 07:23 AM   #9
JoeDubya
wow Rich - it seems like such little material to support the weight - but I suppose the band and thinset does add some structure...adding tile to the bottom and side of that will help as well.
Joe
Unread 08-13-2019, 07:42 AM   #10
Trask
Oregon Tile Man
Trask's Avatar
Joe
The cross shelf gets thinset or Kerdi Fix as an adhesive , then it is permanently locked into place with the tile abutting it on all sides . We install slab corner shelves and small benches on The same principle of compression ( locked in by the tile ) and it’s very
Strong !
Trask Bergerson
Astoria, Oregon
Unread 08-13-2019, 08:17 AM   #11
Joe, the absolute minimum shear bond requirement, which would be the bond between the thinset mortar and the Kerdi or Kerdi niche material is 50psi according to ceramic tile industry standards.
So, if you had only 20 square inches of bonded tile on each side of the niche supporting the ends of your niche shelf, that would amount to at least 2,000 pounds of available support. and that doesn't even consider the tiles across the back of the niche. Doubt you'll likely have more weight than that in shampoo bottles.
Unread 08-13-2019, 08:19 AM   #12
Elkski
Elkski's Avatar
I just installed my shelf with thinset. seemed quite sturdy. and now its all tiled in.
Teddy
Unread 08-13-2019, 09:13 AM   #13
Just to clarify, when I've modified mine I've used sealant to bond the two together. I've never tried it with a Kerdi niche specifically but have done it with both Noble and Laticrete foam niches.
Jim Upton
DIYTileGuy
Unread 08-13-2019, 11:27 AM   #14
I'd probably just get a sheet of 1/2" Kerdi board and make a custom niche. You could probably make several out of one sheet.
Unread 09-09-2019, 02:39 PM   #15
rudyrock
Thx guys
I have decided on building a custom niche after reading more posts. Got enough board to use.
I will have a few questions on measurements to match the grout joints later.
Rudy
Rudy
Modifying an MK880 saw FSmyles Professionals' Hangout 11 06-18-2013 08:57 AM
Modifying Silestone cutout jason78 Tile Forum/Advice Board 7 01-03-2012 08:27 PM
modifying the modified bullbarrel Tile Forum/Advice Board 8 07-30-2010 08:42 PM
Modifying Kitchen Backsplash JoeT Tile Forum/Advice Board 6 04-03-2009 10:51 AM
Modifying Your Thinset??? David Dodson Professionals' Hangout 6 04-27-2005 05:12 PM
