Unread 07-30-2019, 03:06 PM   #1
Hp
Installing porclain distressed tile help
I found some tile today that I love. The back is red and feels just like brick. It says it is made from clay/brick. The lady I bought it from said that it is porcelain but I'm concerned. It is also distressed and has little tiny holes which I love.
My question - when installing won't grout get into those little holes? How can I prevent this.
see picture attached
Hp
Hp is offline   Reply With Quote
Unread 07-30-2019, 03:29 PM   #2
Lou_MA
Yes.
Grout a spare tile or two to see if you like the look. If grout in those holes bothers you, you’ll have to tape off each tile face.
Lou
Unread 07-30-2019, 06:20 PM   #3
I'd fill them in with grout. If you don't, the holes will fill in with dirt or food ( on a back splash). Or tape them off like Lou said.
Unread 07-31-2019, 07:10 AM   #4
Metropolitan Ceramics
Tile can be porcelain and still be red on the back. Porcelain just means that it absorbs less than 0.5% moisture when wet. Depending on the type of clay used it can be red, buff (yellowish), or gray and still be porcelain. If there is a 'Certified by PTCA' logo somewhere on the box, you know that it has been third party verified as actual porcelain, otherwise you're just taking someone's word for it.
A grout release can keep grout out of the holes. Typically these are waxy products that cover the surface and then you wash them away as part of the final grouting step. As was mentioned earlier though, if it's going on a floor you will get dirt down in those voids and it will end up being dark gray anyway. Using a dark gray grout and just letting it fill them in may be your best bet. Try it on a few pieces first and make sure you like the look before you mortar them in place.
Dan Marvin - VP of Operations
www.ironrock.com
Metropolitan Ceramics is online now   Reply With Quote
I'm installing distressed stone tiles with lots of craters in the tile. Terry the amateur Tile Forum/Advice Board 2 07-26-2012 04:54 AM
Help: Porclain granite tile unglazed LisaL1428 Tile Forum/Advice Board 6 10-27-2009 03:45 AM
Bathroom black porclain wall tile problem rayjay2008 Cleaning, Restoration and Sealing 8 05-30-2009 05:38 AM
Replace 2 Large Porclain Tiles ardolino Tile Forum/Advice Board 1 08-04-2008 06:06 AM
Laying tile floor with distressed edge mkmj Tile Forum/Advice Board 7 05-06-2008 12:51 PM
