Unread 07-19-2019, 09:06 PM   #1
Nathanlv30
Resizing large format
I tore out tub and shower in my master bath and prefer not to pull up the tile floor as well. I found some porcelain 12×24 for the shower walls and tub surround that I like and compliment the existing floor pretty well. I've been picturing a herringbone pattern on the shower floor but can't seem to find a tile I'm ecstatic about (no doubt there's plenty I'm sure discarding time and budget). Is it a ridiculous idea to cut down some of the 12×24's to 6×12 and use them? They only have a micro bevel and matching core, so filing the saw cut edges of 18 sf wouldn't be a huge chore. Any thoughts would be greatly appreciated, but please go easy on an ignorant carpenter 😉.
Nathan
Nathanlv30 is offline   Reply With Quote
Unread 07-19-2019, 09:15 PM   #2
Welcome, Nathan.
A 6"x12" tile is very large to try to tile a traditional center drain shower floor. And if your shower has a linear drain at one end the tiles are still pretty large when considering slip/fall possibilities.
Nothing at all wrong with cutting down your existing tiles to make what you want if your tile and talent will allow, though.
Unread 07-20-2019, 12:51 AM   #3
Nathanlv30
Thank you
Much appreciation for your feedback. Yes, I did opt to go with a linear drain but am in agreement that sizing down would be a good idea for safety and probably aesthetics as well.
Nathan
Unread 07-20-2019, 08:41 AM   #4
Two main reasons why a typical shower floor uses smaller tiles:
- on a center drain, with the multiple slopes, it's hard to keep lippage down with larger tile to follow the slopes which often tends to be more of a bowl
- the edges and grout lines tend to give you more friction to fight against slipping in that wet, sometimes messy environment with soap and condition flowing
NOt all tile have a very good wet friction rating...in fact, not all that many do.
Unread 07-20-2019, 11:40 AM   #5
Elkski
Elkski's Avatar
Do a test cut with a plunge saw and see how bad the chipping is. You really can clean up most edges if the chips are small using a stone and some elbow grease. I'm using full 12 x 24 in my shower I think they feel like 500 grit sandpaper on the surface so I think it will be okay
Teddy
Unread 07-24-2019, 06:54 PM   #6
workhurts
Unless you have a great saw and do it consistently, I can't even begin to imagine trying to do that consistently.
Can't go wrong experimenting.
One additional data point. My 12x24 floor hasn't been slippery but it's likely very tile dependent.
Charlie
Unread 08-06-2019, 07:46 PM   #7
Nathanlv30
Altering tile color
Was laying out shower floor for 2x2 porcelain mosaics last night and had a thought of altering color of select tiles slightly to create a darkening effect the last few tiles around the stall perimeter. I was under the impression that water couldn't penetrate porcelain tile, but from what I've read in the forum I believe that is incorrect. My thought process is that if water can permeate the surface, then an aniline dye potentially could as well. The tiles have a matte sheen and don't look to have a heavy glazing. I'm going to mess around with some and see what happens (if anything), but would love to hear insight from you guys that have a lot more knowledge of porcelain and glazing process.
I also had a couple other more unrelated general install questions. I've read to keep questions for same projects on one thread, but wasn't sure if that applies when they don't fit the posted title. Thanks for any thoughts or suggestions!
Nathan
Unread 08-06-2019, 08:38 PM   #8
Thread titles matter not much at all here, Nathan, but continuity of project questions does. A moderator can give your thread a more generic title any time you'd like to suggest one.
Are you sure the tiles are glazed?
I'm not at all familiar with aniline dyes, but the answer to your question is simple. I dunno.
Unread 08-07-2019, 05:53 AM   #9
My take is although the body of porcelain tile has a very low water absorption rate, any glaze on top will have almost none. So if your tile is glazed I wouldn't expect much of anything to penetrate the surface without it sitting on the surface for some time.
The roughly 2X2's on my shower floor, and the 12X24's on the main floor, are also glazed with a matte finish.
Unread 08-07-2019, 11:20 AM   #10
Nathanlv30
CX - No, I am not certain they are glazed. They do have a small amount of luster and texture leading me to believe so but nothing like an obvious glossy layer.
In either case, I did some test samples last night and was pleasantly surprised. All the pieces took the dye to varying degrees and actually fairly consistently within each piece. I did six samples total with one group receiving a moderate dye mix and the other with a fairly concentrated mix. Of the three tiles in each group, one I applied dye directly to the manufactured surface, sanded the surface of one with 150 grit prior to applying dye, and completely submerged the other. The abraded surfaces took color the best (which I think supports the possibility of being glazed) but the two submerged accepted color a lot more consistently than expected in their entirety.
Hopefully tonight, I want to break them open and see penetration. Also, I'm curious how much color will remain after a heavy scrubbing. A discolored grout path to the drain wouldn't be ideal.
Nathan
large format tile 2011js1423 Tile Forum/Advice Board 3 04-18-2011 09:02 PM
thinset - large format kerdi, large format heat Rutili Tile Forum/Advice Board 2 04-07-2008 10:51 PM
Large Format tiles. branty1uk Professionals' Hangout 16 04-11-2006 06:30 AM
large format install Dan Kramer Professionals' Hangout 16 07-09-2004 10:27 PM
Large format installs RandyL Professionals' Hangout 8 03-03-2004 09:19 PM
