Unread 07-04-2019, 10:57 AM   #1
loopyrlm
How level is level ?
Greetings all,
I'm getting ready to install 3"x 6" subway tile as a backsplash in the kitchen. I have found that the countertop is not perfectly level. It drops 1/2" over a 15 foot span. Leveling the cabinets and countertop is not an option at this point. Is this enough of a drop to worry about or should I be cutting slivers off of all the 1st course tiles.
Thanks for any help.
Randy
loopyrlm is offline   Reply With Quote
Unread 07-04-2019, 11:08 AM   #2
Welcome, Randy.
Have you checked the level of the upper cabinets, too. You'll be tiling all the way to the bottom of the uppers, yes?
I'd mark a level line for the tops of your bottom row, measured from the lowest point on the counter top and cut the bottom of the bottom row of tiles to make the tops fit that line. Be sure to allow for a gap of 1/8th" between the bottom row and the counter top as a movement accommodation joint to be filled with a flexible sealant.
Unread 07-04-2019, 11:23 AM   #3
loopyrlm
Thanks CX,
The distance from the countertop to the bottom of the cabinets is 18" the whole way. If I do cut the tiles on the first row I will be taking about 1/64" off of each. i do have a wet saw but am not sure if i can slice that small of a piece off.
Randy
Unread 07-04-2019, 12:45 PM   #4
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I'd follow the cabinets if they're parallel. If indeed six tiles and grout joints exactly equal distance from countertop to bottom of cabs, it's close to a miracle.
If smaller, I'd take the cut at the cabinets. If larger, I'd stretch the pattern a bit with larger grout joints.
Level and looking level are sometimes not the same.
Peter
Carbidetooth is online now   Reply With Quote
Unread 07-04-2019, 01:09 PM   #5
What Peter said.
Unread 07-04-2019, 04:14 PM   #6
loopyrlm
OK Thanks,
I think I'll give that a try. With 1/16" grout lines and a 1/8" gap above the counter top it looks like I will be cutting about 1/4" off the top of each tile on the top row. This should be somewhat hidden by the cabinets. Should be OK.
Thanks for the advice
Randy
level-lite, level-quik, and general SLC inquiries kavita Tile Forum/Advice Board 9 06-19-2005 06:12 PM
level quick that didn't self level jeff ferguson Tile Forum/Advice Board 8 04-27-2005 09:42 PM
Best way to level without SLC? Dan White Tile Forum/Advice Board 8 02-18-2005 10:37 AM
to level or not to level bath floor jmc Tile Forum/Advice Board 12 05-19-2002 09:22 AM
To Level or not Level Tile Rookie Tile Forum/Advice Board 20 10-18-2001 03:13 PM
