Unread 07-02-2019, 10:08 AM   #1
Boston_guy
1850s Kitchen
Hello all newbie here. I am renovating my kitchen in an old wood framed house. My joists are the original 1850's true 2x8s 19.2 in. o.c. and I may do some additional blocking and sistering as needed but the deflectometer gives me a thumbs up for ceramic even before that.
The old kitchen circa mid 1980's has two sheets of 3/4 in. ply, with 1/4 in. thick 6"x6" ceramic tiles laid directly onto the plywood with a very thin mortar set. So total height was 1 3/4 in. Not using any backer board was necessary - and presumably still an approved method back then - because the remaining old pine wood floor was 5/8 in flooring on top of 1 in. planks. So the total difference between the tile and wood floor was about 1/8 inch, bridged with a small metal threshold.
My dilemma now is how to best setup my new floor for success keeping it strong but not making it much higher than 1 5/8 in of the remaining floor. Adding hardiboard onto the existing two sheets of plywood would make it too high.
Options?
- Two sheets of 3/4in plywood and use TAVY thin skin system -assuming this is frowned upon in this forum?
- One sheet of 3/4 in plywood, another sheet of 1/2 inch, 1/4 in hardiboard ?
What else? Thanks all
Willy
Boston_guy is offline   Reply With Quote
Unread 07-04-2019, 10:56 AM   #2
Hi Willy,
The two layers of 3/4 will be the strongest, but I'm not sold on Tavy thin skin. Using your second suggestion is probably the way to go.
SB's Kitchen SBSB Tile Forum/Advice Board 2 02-17-2018 07:54 PM
new kitchen craigrrr Tile Forum/Advice Board 4 11-11-2013 02:46 PM
Kitchen Kitchen Counter - Edging & Underlayment Questions Mark in Breck Tile Forum/Advice Board 5 06-01-2007 09:00 PM
Big kitchen job BPATTON Tile Forum/Advice Board 12 01-25-2004 01:17 PM
FP and Kitchen done - what do you think? dmoolenaar Tile Forum/Advice Board 25 11-23-2003 11:42 AM
