Unread 06-30-2019, 03:10 PM   #1
Fionn
Removing Thinset from Backerboard
I am trying to replace some cracked and loose tiles. I have the tiles and and while the thinset did not adhere well to the tiles, it has adhered very well to the backerboard.
I got up a little with a putty knife and hammer but it did pull some of the surface off of the backerboard. Is there a way to remove the old thinset without damaging the backerboard?
Fionn
Fionn is offline   Reply With Quote
Unread 06-30-2019, 04:55 PM   #2
Lou_MA
A rub stone like this https://www.homedepot.com/p/Marshall...0-HD/100318060
Or a fein tool or similar with a carbide rasp
Lou
Unread 06-30-2019, 06:29 PM   #3
Fionn
Thanks, Lou. I am actually working with the rub stone. It is fairly slow but it is doing the trick.
Fionn
Unread 07-01-2019, 06:30 AM   #4
Hi Fionn,
The best way I know of is to use a small cold chisel and hammer. You will do some damage to the backer board, but that can be filled in with thinset when you install the new tiles. Thinset is very hard materiel and will take forever to remove with a rubbing stone.
Another idea: If you have a grinder you can grind off the backs of the replacement tiles to accommodate the dried thinset.
Unread 07-01-2019, 06:40 AM   #5
Fionn
Thanks, John. I was thinking of just knocking down the thinset some then using an adhesive to reset the tiles. Would that make sense? There are only 5 tiles that have to be reset.
Fionn
Unread 07-01-2019, 04:51 PM   #6
Yes. I would make sure the adhesive is a thinset that you mix with water. Not premixed.
Removing backerboard alabill Tile Forum/Advice Board 6 10-24-2013 07:09 AM
Removing Hardie Backerboard jcmartin217 Tile Forum/Advice Board 3 08-12-2013 07:32 AM
Removing Bad Backerboard Screws Dougit Tile Forum/Advice Board 7 09-25-2008 09:33 AM
removing backerboard Scott2003 Tile Forum/Advice Board 9 06-29-2008 02:24 PM
Thinset under backerboard smason414 Tile Forum/Advice Board 6 11-26-2007 08:20 PM
