Unread 06-30-2019, 06:18 AM   #1
H20xpurt
Hardwood or Tile First
I am installing a new floor in my office and would like to do a 5 foot strip of tile in the middle of the office and hardwood in the rest of the office. I plan on having the hardwood installed and I will do the tile. Would you recommend the hardwood be installed first then the tile or vice versa? I plan on Ditra, tile and schluter tile edge.
David
H20xpurt is offline   Reply With Quote
Unread 06-30-2019, 06:43 AM   #2
Elkski
Elkski's Avatar
I'm pretty sure you will want to install the hardwood first if it is unfinished and need sanding and coating. Metal strip will make it hard to ever refinish the floors. If 3/4" wood you may need something like ditra to get the tile to similar height. I imagine after the wood is in you can put the ditra down then metal trim next to the wood. Some metal trims like Jolly are not vertical outside walls. plus you're going to want some type of expansion joint so I think you should consider the dilex-bwa.
Teddy
Unread 06-30-2019, 07:57 AM   #3
In the new custom homes I've done the tile always went in first and was then protected while the wood went in and was finished.
extending fireplace hearth over hardwood, dont want to tear up hardwood brants Tile Forum/Advice Board 18 12-18-2017 03:03 PM
Hardwood/Tile Transition - Cutting Hardwood Bengal Tile Forum/Advice Board 5 05-24-2009 08:53 PM
Tile over hardwood? Jeremy J Tile Forum/Advice Board 3 09-06-2008 09:23 PM
Tile over hardwood? jscrock Tile Forum/Advice Board 5 01-04-2007 03:15 AM
tile over hardwood ddj Tile Forum/Advice Board 2 02-12-2002 06:04 AM
