Unread 06-20-2019, 03:04 PM   #1
istion
How to finish tiles at ceiling
Wondering what the best way of finishing this is as my tiles don't fully reach the ceiling there is a gap
Ken.
DIY'er. Not naturally talented, but persistant.
istion is offline   Reply With Quote
Unread 06-20-2019, 04:05 PM   #2
john619
1. insert schluter reveal at top and trim tiles to it.
2. add applied crown moulding piece over top of what you have.
3. apply another layer of gyp. board to the ceiling held back 3/4" from all perimeter walls to create a reveal that your tile will disappear into.
4. I have others.............
john
Unread 06-20-2019, 04:27 PM   #3
istion
Thanks... on the schlueter reveal... do you mean putting a jolly Edge so runs flush against the top of the ceiling even if I have to trim that edge?
Ken.
Unread 06-20-2019, 05:34 PM   #4
How big is the gap?
Unread 06-20-2019, 05:45 PM   #5
istion
Off hand as I'm not there currently I believe it to be about an eighth of an inch. Maybe a smidge more. Depending on the tile
Ken.
Unread 06-20-2019, 07:01 PM   #6
Elkski
Elkski's Avatar
I have this same issue. my gap is 1/4" i am thinking of some little bit of molding maybe even some quarter round cut down to 5/16".
With all my different elevations to worry about no slivers if this is all my issue I will be ok.
Teddy
Unread 06-20-2019, 07:04 PM   #7
Elkski
Elkski's Avatar
Question
Teddy
Unread 06-20-2019, 07:53 PM   #8
White caulking, or caulk that matches the grout.
Unread 06-20-2019, 07:54 PM   #9
istion
I thought about that.... any pics of such a thing??
Ken.
Unread 06-20-2019, 10:42 PM   #10
Yeah, caulk. This is one of the only times I use a latex caulk (because it’s paintable). If you can, use a foam backer rod in the joint before caulking to make the caulk perform better and last longer. You can buy foam backer rod by-the-foot for a few cents from a decent old-fashioned hardware store.
Wedi bathtub - finish without tiles? zikzak Tile Forum/Advice Board 6 01-02-2015 08:53 AM
Finish came off tiles Ellensue Cleaning, Restoration and Sealing 1 11-30-2013 05:16 PM
Slate tiles - Getting a good finish Private65 Cleaning, Restoration and Sealing 17 05-17-2006 08:38 AM
Ceiling finish banmj Tile Forum/Advice Board 9 03-20-2006 02:43 PM
Spacing & finish of geometric tiles Calypso Tile Forum/Advice Board 1 01-05-2004 02:01 PM
