Unread 06-07-2019, 01:00 AM   #1
matt22
Pool Tile 2 x 2 Notch Trowel Size
What size notch trowel would you recommend for a ceramic pool tile
2x2" x 1/4"
in a column of (3) with a 3/4” mortar bed?
matt22 is offline   Reply With Quote
Unread 06-07-2019, 05:00 AM   #2
Radas
Tile Newbie
If I remember correctly, I used a 3/16x3/16 U-notch on my shower floor 2x2 - Marshalltown makes a decent one they sell on Amazon.
I would try that trowel size with a test or scrap section of your mosaic on cardboard or scrap plywood. The best trowel size is one that gives 100% thinset coverage when the 2x2 sheet is fully embedded without bleeding through the grout joints excessively and requiring a lot of cleanup.
Ali
..a new excuse to hoard tools
Unread 06-08-2019, 12:15 AM   #3
Welcome to the forum, Matt.
I'd agree with Ali on the 3/16" trowel, provided you don't use a V-notch trowel. If you can't find anything else, use a 1/4" trowel and hold it at a 45-degree angle when troweling. That'll get you very close to a 3/16" setting bed.
Trowel Notch Size Sawdustguy* Tile Forum/Advice Board 5 07-29-2018 05:29 PM
Trowel Notch Size for 12x24 Floor Tile dan737 Tile Forum/Advice Board 6 03-31-2015 07:26 PM
Rialto porcelain tile trowel notch size huggins Tile Forum/Advice Board 4 02-18-2008 09:15 PM
What size trowel notch for a 20 x 20 tile? JAuld Tile Forum/Advice Board 4 05-21-2007 09:48 PM
what size notch trowel doitmislf Tile Forum/Advice Board 3 02-14-2005 07:39 PM
