Unread 05-20-2019, 07:15 AM   #1
SpaceCadet
cleaning up tile spacers
I re-use tile spacers and it takes a while to clean them up after I pull them out of the wall. Naturally the thinset is hard by then. Usually just scrape the stuff off with a sponge, wire brush, or my fingers. Any trick to cleaning them quickly? These are the brutus plastic horse-shoe type spacers.
Paul
SpaceCadet is offline   Reply With Quote
Unread 05-20-2019, 07:31 AM   #2
makethatkerdistick
I just clean mine mechanically in crucial spots so I can reuse them. If you want them completely clean you could try something like this. This also works for tools that have dried mortar on them.
https://www.custombuildingproducts.c...d-cleaner.aspx
Wolfgang
Unread 05-20-2019, 07:49 AM   #3
Paul, when I use hard plastic wedges I keep a one-gallon bucket at hand with a strong vinegar solution in it and just toss the spacers in that as I remove them. very easy to rinse off any mortar after they soak a while. I prefer to use the 9% vinegar rather than the usual 5% solution.
Unread 05-23-2019, 07:01 AM   #4
SpaceCadet
Thank you. The vinegar worked great. I'll keep the CBP stuff in mind if I need something more powerful.
Paul
Unread 05-23-2019, 07:40 PM   #5
thuffner3
I put ours in a 5 gal bucket of clean water and spin the mixer on then, does a right nice job.
Neil
Neil Jackson, from Cincinnati, Ohio
Her contractor said she could have it installed today.
thuffner3 is offline   Reply With Quote
Unread 05-25-2019, 09:04 AM   #6
Tiger Mountain Tile Inc
I've gone straight for the muriatic acid before. No messing around.
Jim Upton
DIYTileGuy
spacers or no spacers for subway tile T@StPete Tile Forum/Advice Board 5 07-27-2015 07:18 AM
Tile Spacers moneymoe777 Tile Forum/Advice Board 4 02-05-2009 10:07 PM
Tile Spacers Gunner Tile Forum/Advice Board 6 03-20-2008 09:50 PM
better tile spacers tilesnake Professionals' Hangout 21 02-24-2004 11:36 AM
Re-Using Tile Spacers Robert Villa Professionals' Hangout 12 10-25-2002 10:33 PM
