Unread 03-09-2019, 11:32 AM   #1
Sledgeyj
Kerdi drain flange too low
Thanks in advance to all who offer advice.
I am in the process of installing the schluter shower kit. I have the foam pan mortared down several weeks ago. Issue I just realized today is the drain flange sits 1/4" lower than the floor of the pan. I assume that is going to be an issue that needs to be addressed prior to me installing the Kerdi on the floor. Please advise how to address this.
Thanks again for sharing your expertise
Sledge
Sledgeyj is offline   Reply With Quote
Unread 03-09-2019, 11:55 AM   #2
Gozo
If the drain is not in yet, just use a thicker mortar bed when setting it and don’t smoosh it down all the way to meet the foam tray.
I had not realized this when setting mine and got the same slight recess of the drain flange from the plane of the pan. Kerdied over it and had a divot to deal with when laying the tiles. Wound up just getting the tiles up to the slope plane with the mortar when setting the tiles. Hasn’t been an issue at all.
Make sure to do a flood test before tiling for peace of mind.
Post pictures. We love pictures.
Jeff
Unread 03-09-2019, 11:57 AM   #3
Sledgeyj
Flange is set but not drain grate assembly. But as it is, the tile won't sit right....
Sledge
Unread 03-09-2019, 12:07 PM   #4
Gozo
is this the stage you’re at?
https://www.johnbridge.com/vbulletin...1&d=1500338748
If so, don’t make yourself crazy. You can Kerdi and level the divot with some medium set mortar (many “thinset” mortars are classified for up to 1/2” which is more than you’ll need), or level it first and then place the Kerdi.
Others will jump in with various options. I’m just a DIY slob like so many of us here, so I can’t attest to if it’s “kosher” or not, but only to if it worked for me.
Jeff
Unread 03-09-2019, 12:15 PM   #5
Sledgeyj
Yes, exactly
Sledge
Unread 03-09-2019, 03:08 PM   #6
Looks like Jeff pretty well covered it, Sledge.
Kerdi drain flange covered by pan?!?! MarvalSam Tile Forum/Advice Board 6 03-30-2018 01:46 PM
Is this Kerdi drain flange going to bond correctly? bernz Tile Forum/Advice Board 17 08-13-2014 07:10 PM
retro kerdi drain into flange drain? figaro Professionals' Hangout 11 12-20-2012 04:02 PM
Toilet flange / Kerdi Drain advice FGH Tile Forum/Advice Board 6 12-19-2010 10:40 AM
A Kerdi drain flange question TrimGuy Tile Forum/Advice Board 6 05-17-2009 08:43 AM
