Unread 01-18-2017, 05:02 PM   #1
jmon22
Removed Fireplace Hearth - How to get ready for tile?
Hello all, just discovered this site today and looks like a great place. Searched old posts but could not find an exact situation that I'm facing. Removed an old brick hearth and want to retile with marble flush to the carpet. I am currently down to a mortar bed which is about 3/4" below the finished carpet level. Not entirely level (certainly not level enough to tile). What are my next steps here?
1) Try to level this mortar bed as much as possible, and go from there?
2) Take off this mortar bed and build back up? Looks to be concrete block on the back half and non-level bricks on the front section under here (as shown on the side shot of the access hole).
3) What to do with this access hole that was created when the fireplace was set?
Appreciate any and all help
Josh
jmon22 is offline   Reply With Quote
Unread 01-19-2017, 07:31 AM   #2
jmon22
Going to fill the hole with concrete, level the top with a diamond cup blade on an angle grinder, and use ditra over it unless anyone has any better advice before then.
Thanks!!
Josh
Unread 01-19-2017, 08:19 AM   #3
rmckee84
rmckee84's Avatar
That's a dusty route to go, and may be hard to get all those dips and humps out.
I would fill the hole with something packable, then float the area out with any number of products. Ardex AM100 is one that could be applied thin enough and still leave room for the tile to come out flush with the carpet. Basically any cement based patching product that is rated to whatever depth you need to build up would suffice.
Ryan McKee
Enlarging fireplace hearth and tiling hearth and surround Kate1569 Tile Forum/Advice Board 65 12-31-2016 08:40 AM
Getting a demolished hearth ready for new tile sugarbeth Tile Forum/Advice Board 9 04-08-2009 07:39 PM
Help with Fireplace/Hearth tile prep RichRyan Tile Forum/Advice Board 16 01-12-2009 12:26 PM
New tile on fireplace and hearth Tileboy 65 Tile Forum/Advice Board 5 05-07-2007 01:29 PM
First Tile Job - Fireplace surround and hearth LKirc Tile Forum/Advice Board 4 01-18-2005 11:45 AM
