Unread 01-13-2017, 11:25 AM   #1
kbrophy
Kerdi membrane over drywall mud
I am getting ready to install kerdi in my bathtub surround. I have hardibacker all around the tub but the installers used drywall mud to join where the drywall and hardibacker meet and this seam extends into the tub where I want the kerdi to be.
Question:
I started to sand it off but is another option to prime the the mudded areas? If so, latex or oil?
Also, I really want to tile to the ceiling (just using 3x6 tiles) and also have mud above the showerhead height. Tile shop told me to just use mastik up there because it will not get very wet and I don't know whether that is all hardibacker or partially drywall at the very top.
Any advice would be greatly appreciated.Name:  IMG_2688.jpg
Sorry if the pic is sideways :/
Kara
kbrophy is offline   Reply With Quote
Unread 01-13-2017, 05:18 PM   #2
rmckee84
rmckee84's Avatar
1. Best thing to do is remove as much mud as possible. A sanding block, and a wet sponge can get the majority off.
2. While there are some that are technically approved for intermittent wet areas I personally would have it anywhere near a shower. It costs more than thinset, contains organic matter that can grow mold and mildew, and also doesn't jive with schluter products.
Ryan McKee
Unread 01-13-2017, 05:51 PM   #3
Drywall installers usually use the premixed drywall mud. If that's the case, fill a spray bottle with plain water and spritz an area very well, let it sit for a few minutes maybe adding some more if you see it drying out, and you'll be able to remove most of it with a putty knife as a paste (no dust!). What's left will usually wash off with a sponge fairly easily. If they used a setting compound they mixed up with water (i.e., dry powder), then spraying it won't work! You'll want an alkali resistant mesh tape for the seams...well, you really don't need that at all if you're putting Kerdi over it! The Kerdi is way stronger than the mesh tape and will perform the same function.
Unless this is a steam shower, which it doesn't appear to be, regular drywall should be fine on the ceiling. YOu may want to add more drywall screws, since installers often don't put in enough. If you have the industry standard amount and spacing of fasteners, drywall will hold tile just fine on the ceiling. If there's a joint and you're not using Kerdi there, I would use the mesh tape on the seams. You do not need to do this prior to tiling, you can do it during. If there's a seam there, and the tapered edges are at the seam, you might want to fill that area with the tape and thinset prior, so that it is level with the rest of the surface. If you're using a large enough tile, it probably wont' make any difference, but otherwise, your tile might follow that dip when setting the tile. THe magic to getting tile to hold overhead is properly embedding them and having the proper consistency of your mortar.
Drywall seams under Kerdi membrane - Seeking advice thewitz Tile Forum/Advice Board 5 10-16-2016 08:55 AM
After adhering Kerdi membrane, drywall behind was very damp ofairlane Tile Forum/Advice Board 19 05-01-2016 11:13 AM
Purple or regular drywall with Kerdi membrane? BNR Tile Forum/Advice Board 5 12-15-2014 05:14 PM
kerdi on drywall with fresh drywall compound aaron0593 Tile Forum/Advice Board 12 02-04-2013 11:23 PM
Kerdi Membrane on painted drywall ulcus Tile Forum/Advice Board 2 11-18-2008 12:27 PM
