Unread 01-08-2017, 11:53 PM   #1
millie404
Tile Pro Advice Needed - Flatness ANSI A108.02
Hello John Bridges Community!
millie404 is offline   Reply With Quote
Unread 01-09-2017, 07:26 AM   #2
chrishmm69
I cant tell from the pictures if you are using the pennies to make the level *level* or if there are peaks and valleys under the level itself.
Your floor needs to be *flat* but not necessarily *level*. If you put the level down on the floor (no pennies), can you see light peering through in spots under the level? If so, thats what you might be able to complain about.
Its also possible that the contractor did in fact flatten out your subfloor, but didnt install the tiles flat to each other.
Chris
chrishmm69 is offline   Reply With Quote
Unread 01-09-2017, 11:24 AM   #3
Welcome, Millie.
Appears you've deleted all the useful information from your post, making it difficult for us to be of any help. Was that your intent?
Tile Shower Drain Flatness & PVC Flex takatsu Tile Forum/Advice Board 2 10-09-2012 01:43 PM
Question about ANSI A108.15 Levi the Tile Guy Professionals' Hangout 18 05-30-2011 04:33 PM
ANSI Standards Information Needed ob1kanobee Professionals' Hangout 10 11-28-2010 05:12 PM
Tile Saw Advice Needed (Come one, Come All) Wood_butcher Professionals' Hangout 41 09-27-2004 09:48 PM
A108 quarter round @ cbu zevlagdm Tile Forum/Advice Board 1 06-15-2002 11:44 AM
