Unread 01-07-2017, 06:09 PM   #1
reckebecca
Advice needed - corian transition/threshold loose
I have an issue I am hoping that all you brilliant minds can help me to solve!
I had a walk-in shower + bathroom tile installed 2 years ago. The shower floor is pebble, the shower walls and bathroom floor are ceramic tile. My tile installer used a piece of Corian for a transition from the pebble to the tile. He did not fully grout the end between wall tile and top of Corian transition piece. Corian has now come loose at one end, allowing water to go underneath - not good, I know!
I attempted to reach my tile installer, he's not responding. SO, it's time to figure it out a different way since I'm a relatively handy DIYer.
I used a dremel 570 bit to remove the bits of grout btwn Corian and wall tile and what I thought was loose grout but now believe was caulk between the tile and the Corian. When I attempted to use the 570 between the pebbles and the Corian I got a bit of a muddy mess as there is some residual moisture present so I stopped.
The Corian is "moveable loose" for about 4" from wall and "knock on it, not solidly adhered" for about double that. I cannot get underneath the Corian.
So, then the puzzle becomes how to fix this mess.
One thought was - try to get some gorilla glue beside/beneath it, set something heavy on it (and/or put shims between it and the wall tile as wedge) until gorilla glue dries then re-caulk the Corian to tile edge, grout the wall tile to Corian end and the pebble to Corian side. But, I don't know if the gorilla glue will hold. Don't know if the Tec siliconized color matching caulk would stick to the gorilla glue that would then be at the bottom of that space. And, I don't know if there is a better solution. So, I came here to ask
Thanks in advance for all your thoughts/advice!
~Rebecca
reckebecca is offline   Reply With Quote
Unread 01-07-2017, 06:15 PM   #2
rmckee84
rmckee84's Avatar
If there is moisture under the threshold then it needs to come out and area needs to dry otherwise you'll have a hard time getting anything the cure. Do you know how the shower was constructed, specifically how the installer waterproofed it and how far the waterproofing extends under the floor tile in the main part of the bathroom?
Ryan McKee
Unread 01-07-2017, 07:09 PM   #3
reckebecca
I don't know about the waterproofing
I do know that it is a mudbed underneath the pebbles. I just went looking for pictures and I'm not being able to put my hands on pictures that show anything that would help with this question.
Rebecca
Unread 01-07-2017, 07:56 PM   #4
rmckee84
rmckee84's Avatar
This is pure speculation, but if the threshold is coming loose it could be signs of a bigger issue. Removing it would be my recommendation, that way you can see exactly what is going on at the transition. But from looking at the pic the piece might not survive the removal so that's up to you I guess.
Ryan McKee
Unread 01-07-2017, 09:07 PM   #5
reckebecca
Memory cells finally kicked in - he used Ditra. I've got a question out to someone else who was here while the install was happening to see if we can determine how far he took it out beyond the transition piece.
Yes, I was worried about the Corian piece's survival if it needed to come out.
Rebecca
Unread 01-08-2017, 12:35 PM   #6
rmckee84
rmckee84's Avatar
Let us know what you find out and hopefully we can help. Its just hard to tell exactly the best way to remove the threshold without actually being there.
Ryan McKee
Unread 01-09-2017, 11:38 AM   #7
reckebecca
Understood.
I was really hoping that the answer would be that there was a brilliant solution for re-attaching the loose end vs. pulling it out.
I did leave a hairdryer blowing on each side for extended periods this weekend and it's definitely behaving differently (sounds and feels different when I push down on it). I then sealed it up with "sticky-ass" tape as a temporary hold until I figure out what I'm going to do.
Rebecca
Unread 01-09-2017, 02:34 PM   #8
top_hatt
If you have extra field tile, I would remove the wall tile on 1 side to save corian. But that can create more problems if not done carefully.
Sent from my SM-G930P using Tapatalk
Tom
top_hatt is offline   Reply With Quote
Unread 01-09-2017, 07:14 PM   #9
In the scheme of things, would you accept a joint in the middle of the Corian? You could cut it, and maybe lift it out. On the other hand, a piece that small shouldn't cost all that much. You could probably find a fabricator and they usually will sell small remnants for a fraction of what the 'full retail' price is.
You mentioned Ditra...was that used out in the room? Hopefully, as it is not something specified for use in the shower.
loose tiles & cracking grout - advice needed kas4 Tile Forum/Advice Board 22 08-12-2013 08:13 PM
design and transition advice needed, please bjr72 Tile Forum/Advice Board 36 02-03-2012 11:33 AM
Corian Shower Threshold and seat navigator30 Tile Forum/Advice Board 10 10-03-2010 01:42 PM
Threshold Advice Needed (pics included) jdrogers73 Tile Forum/Advice Board 5 04-18-2008 08:36 AM
Cutting Corian Threshold schucb Tile Forum/Advice Board 3 03-17-2006 03:51 PM
