Unread 01-02-2017, 02:17 PM   #1
itdontworkright
How do I prep for new tile.
Hi all,
I just removed some tiles that were original to my 1968 home. These walls are in the bathroom but not the shower. The tiles removed fairly easily in most places, some places it pulled away the drywall. The previous adhesive is well attached. Can I sand it down and apply new adhesive and ceramic tiles over it? I read about using PVA over it, but not sure which product is best. I'm trying to avoid removing the drywall and having to purchase a cement/hardie backer.
Thanks in advance for your assistance.
Lee
itdontworkright is offline   Reply With Quote
Unread 01-02-2017, 04:20 PM   #2
Lazarus
Lazarus's Avatar
Lee~ You should be able to remove anything loose and then flat trowel it with a decent, modified thinset. Let it cure for a day or so and then use the same thinset, combed and tile away......
Laz...
Unread 01-02-2017, 04:49 PM   #3
What about a coating of Eco Prim Grip?
Unread 01-02-2017, 05:19 PM   #4
itdontworkright
Is this a decent thinset? "TEC Skill Set Totalflex 40-lb White Powder Polymer-Modified Thinset Mortar"
Lee
Prep remaining tile pitterpat Tile Forum/Advice Board 12 01-30-2017 07:34 PM
Wall prep for tile coopns Tile Forum/Advice Board 8 09-19-2011 07:36 PM
Tile Prep Help burton8012 Tile Forum/Advice Board 1 02-14-2011 03:14 PM
Pre-tile prep (aka subflooring) arguile Tile Forum/Advice Board 3 07-03-2008 10:26 AM
Need Help With Tub Prep For Tile Iggy Tile Forum/Advice Board 1 07-07-2005 07:38 PM
