Unread 01-01-2017, 05:32 PM   #1
Apme123
Danton
Is this water intrusion?
Hey guys. I am helping my cousin paint the inside of her house. I noticed that there were nail holes popping in the wall behind the tiled shower. I scraped them with a knife and rusty old nails came out. I took a look at the other side of the shower and this is what the pan looks like. I noticed the sheetrock is rusty. The last couple of pictures are of another shower downstairs. Thanks for any and all help.
Also is there a way to check if there is actual water intrusion?? Maybe with a moisture meter?
Danton
Apme123 is offline   Reply With Quote
Unread 01-01-2017, 08:12 PM   #2
rmckee84
rmckee84's Avatar
Doesn't look like it to me, a nail head can rust just because of the joint compound used to cover the head. The pictures with the wire lathe show some rust, but it's hard to say if theres really an issue. Was anything in the wall cavity actually damp?
Ryan McKee
Unread 01-01-2017, 08:15 PM   #3
It looks like a lead pan from the 1950's. The mud will be at least an inch thick, possibly up to 1 1/2 thick and back then they didn't put moisture barriers behind the mud. If it's not showing any signs of leaking under the shower, I'd leave it alone. I don't see a problem with a little rust on the nail head or lath.
Unread 01-01-2017, 08:19 PM   #4
Is that a lead pan liner? Can you tell if it is flat on the floor?
Mudded walls are a nice way to get a flat wall. Lead pans are rarely installed with a preslope, though. That can lead to moisture buildup in the pan, and it can wick up the walls.
Unread 01-01-2017, 08:31 PM   #5
Apme123
Danton
Thanks, I'll take a look and see if it's flat on the floor. Do you guys think plugging the drain and filling it with an inch and 1/2 of water to see if it leaks is a good idea? Thanks for taking the time to help.
Danton
Unread 01-01-2017, 09:18 PM   #6
That wouldn't hurt, but I'd go within maybe 1.5" of the top of the curb or so...maybe 2", depends on how thick the tile and mortar is on top of the liner at the curb. The mortar bed will absorb some moisture, so the level will drop until things are saturated. If the drain has working weepholes, your plug must be below them to check for leaks.
water jet cut mosaic mounted on water soluble glued mat!!!!!!!! johnbuzz Professionals' Hangout 20 11-18-2016 08:13 AM
Tile Floors and Water Intrusion ?s jeffbrig Tile Forum/Advice Board 2 08-28-2012 05:10 PM
Well water/City water; makes a difference in grout colour? HomeDepotAssociate Tile Forum/Advice Board 8 02-26-2012 11:12 AM
A water intrusion mystery (at least for me) royk Tile Forum/Advice Board 3 07-14-2011 06:08 AM
Please pardon the intrusion pros ---- Oldrem Professionals' Hangout 7 04-15-2006 03:36 PM
