Unread 12-28-2016, 11:09 AM   #1
kd5exp
going around a corner.
I am trying to build a walk in shower for my wife that has had a stroke. I took out the shower tub fiberglass part by cutting it in three pieces. I was going to build a bench so she could sit on the toilet and slide over onto the bench. I was told that the water would run out from the bench. So I built a wall there with 2 by 4s and worked out good. My question is how to tile around this 2 by 4 wall and make it look nice. It is all done in 6 by 6 white tile. I cannot find any corner tile to wrap around and butting the tile together I don't think would look good. Any suggestions on how to proceed. This is my first shower and have just about wore youtube out watching how to do this. I can't seem to find anything out on this part. I found this site and hoping I will get some suggestions. Thanks in advance.
Gene
kd5exp is offline   Reply With Quote
Unread 12-28-2016, 11:22 AM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
Welcome Gene, I've never liked the looks of butted bullnose either, but there are alternatives.
I'd likely choose a Schluter profile designed just for this purpose
http://www.schluter.com/schluter-us/...r-Walls/c/P-FW
Peter
Carbidetooth is online now   Reply With Quote
Unread 12-29-2016, 03:05 AM   #3
EthylOH
Hi Gene,
I would just cut down one of the tiles on each side (so that the tile has square edges) so that it fits evenly on the end of the wall. Then overlap the tile with bullnose on each side.
It should look like this:
Jon
EthylOH is offline   Reply With Quote
Unread 12-29-2016, 10:15 AM   #4
Jon,
Gene's question is how to handle the corner when bullnoses aren't available.
Unread 12-29-2016, 10:31 AM   #5
Welcome, Gene.
If I understand your situation, I generally miter the corners by back-beveling the tile on each side and grouting the resulting joint. Here's one example of some 6"x6" glazed wall tile done that way.
Name:  Mitered Corner.jpg
Size:  43.4 KB Cut your tile like so: Name:  back mitering tile.jpg
Flower pot is optional.
Unread 12-29-2016, 08:08 PM   #6
That's a fine drawing.
Unread 12-29-2016, 08:44 PM   #7
kd5exp
I like the looks of that miter cut corner. I will play with that and see what I can do. Thanks CX
Gene
Creating corner on island with quartz and no corner or bull nose pieces Chicagorealestate Tile Forum/Advice Board 4 10-25-2013 05:27 PM
SLC in this corner? Robert Fahey Tile Forum/Advice Board 15 07-11-2013 01:26 PM
Outside corner help cnousen Tile Forum/Advice Board 6 06-17-2012 05:02 PM
corner bead for drywall/cement board corner FJK Tile Forum/Advice Board 11 07-10-2011 01:33 PM
Dam Corner Icandoit Tile Forum/Advice Board 3 08-02-2005 01:16 PM
